12 voltsproblem
Re: 12 voltsproblem
Och jag råkade ut för exakt samma sak förra veckan. Tesla P85 uttagen 2014-04, 6k mil på mätaren.
Batteriepidemi
Batteriepidemi
- Teslaspolen
Re: 12 voltsproblem
Sparkar liv i den här gamla tråden igen då jag snackade lite med en kille i USA som säljer litiumbaserade 12v batterier (https://www.ohmmu.com/). Det har nämnts ett par gånger på forumet, och det vi har återkommit till flertalet gånger är problemet att ladda dessa celler i vårt kalla klimat. (i.e Vad händer när det är minus 10/20/30 grader?...) Så jag passade helt enkelt på att fråga honom vad hans åsikt om det är.
Om inte annat så känns det som det hade varit intressant att göra bara för att se vad som händer. For science!Hi!
So good to hear from you!
Although the 12v battery is not insulated from the cold temperatures it does receive some benefit from its proximity to other components which are warmed during vehicle operation. The chemistry we use is not the same as the tesla traction battery pack, we use Lithium Iron Phosphate, which is known to be safer than other lithium chemistries and a bit more resilient to cold temperatures. We have done cold weather testing and have found that the batteries perform well within the vehicle system but do experience some shortening of lifespan with continuous exposure to extreme cold.
The problem as you know is with the charging of the batteries, not the discharging, discharging at -25C isn't as big of a problem as charging at -25C. Charging can be done at -25C safely but only if it is done VERY slowly. Generally the tesla vehicles aren't charging the 12v batteries with much current unless the vehicles are powered "on", when the vehicles is powered on the battery is provided a little warmth from surrounding components, certainly it doesn't get warm by any means but it does bring -25C up to around 0C and that makes a big difference for the performance of these batteries during charging.
So, in summary; I suggest that the battery will experience some degradation due to extreme cold but a few features of the vehicle/system work to our advantage to minimize this degradation, therefore I have confidence in the performance of these batteries in these extreme cold weather conditions.
Also, if you feel there is enough demand, I have been working on creating an "extreme cold" battery solution which would utilize Lithium-Titanate and/or some self-heating circuit features within the battery; the costs would be significantly higher though. Likely $600-900USD per unit. What are your thoughts on this?
- TeslaTissel
- Kontakt:
Re: 12 voltsproblem
Hupp!? Just denna fråga funderade jag händelsevis på igår!!Teslaspolen skrev:Sparkar liv i den här gamla tråden igen då jag snackade lite med en kille i USA som säljer litiumbaserade 12v batterier (https://www.ohmmu.com/). Det har nämnts ett par gånger på forumet, och det vi har återkommit till flertalet gånger är problemet att ladda dessa celler i vårt kalla klimat. (i.e Vad händer när det är minus 10/20/30 grader?...) Så jag passade helt enkelt på att fråga honom vad hans åsikt om det är.
Sitter dessa i ALLA Teslor vi får till EU?
De är ju endast att se som hjälpbatteri? Om jag fattar rätt.
Re: 12 voltsproblem
Ska det kosta 5-10 tusen för att få det att fungera bra så byter jag hellre ett batteri för tusenlappen med några års mellanrum, och att tro
att man kan slänga in ett vanligt litium-12V-batteri i en Tesla som inte tar hänsyn till hur batteriet tål att laddas i låga temperaturer (eftersom
systemet inte behöver bry sig som det är konstruerat idag) kommer bara leda till att man förstör batteriet rätt snabbt.
Däremot borde det gå att få till lite värme till batteriet när det är kallt på det gamla hederliga sättet (typ en värmeplatta med termostat under batteriet) och då
skulle det funka med ett vanligt litiumbatteri (under förutsättning att Teslan verkligen laddar batteriet även när bilen är avstängd så att den lilla strömmen
som behövs för värmaren inte drar ur batteriet helt istället.
Å andra sidan så vettifasiken om inte Tesla har löst grundproblemet redan för numera hör man inte ofta att 12V-batteriet har säckat ihop, eller?
- Teslaspolen
Re: 12 voltsproblem
Förstår inte vad du menar. Detta rör sig om ett batteri från tredjepart gjort på litiumceller istället för bly-syra som annars sitter i alla Tesla bilar.TeslaTissel skrev:Hupp!? Just denna fråga funderade jag händelsevis på igår!!Teslaspolen skrev:Sparkar liv i den här gamla tråden igen då jag snackade lite med en kille i USA som säljer litiumbaserade 12v batterier (https://www.ohmmu.com/). Det har nämnts ett par gånger på forumet, och det vi har återkommit till flertalet gånger är problemet att ladda dessa celler i vårt kalla klimat. (i.e Vad händer när det är minus 10/20/30 grader?...) Så jag passade helt enkelt på att fråga honom vad hans åsikt om det är.
- TeslaTissel
- Kontakt:
Re: 12 voltsproblem
Förstår inte vad du menar. Detta rör sig om ett batteri från tredjepart gjort på litiumceller istället för bly-syra som annars sitter i alla Tesla bilar.[/quote]Hupp!? Just denna fråga funderade jag händelsevis på igår!!
Jag menade att det var ett nytt batteri (från Tesla) som ersätter de tidigare batteriet.
Men då förstår jag. Det är ett standard-batteri som levereras i alla Teslor,
Tack!
Re: 12 voltsproblem
Mitt problem kom när jag aktiverade sleep mode eller sparläge. Efter det så fick jag larmet. Så antagligen laddar den 12v mindre frekvent vid sparläge.
Hade hållt sig i närmare 2år
Re: 12 voltsproblem
Mitt är 3 år 80250km på mätarenkontakten2 skrev:Mitt problem kom när jag aktiverade sleep mode eller sparläge. Efter det så fick jag larmet. Så antagligen laddar den 12v mindre frekvent vid sparläge.
Re: 12 voltsproblem
Svar typ ett år senare... När bilen har låg laddnivå på huvudbatteriet så stödladdar bilen inte längre 12V batteriet och om det då är dåligt så dör det snabbt och bilen slutar fungera.Bjelke skrev:Skulle du kunna fråga sedan om varför låg SoC skulle vara osäkrare för ett dåligt 12V-batteri? Och isf vid vilken nivå blir det problem?
Det känns som att det skulle krävas en sjukt låg SoC för att laddning av 12V-batteriet skulle strula eller att bilen går in i deep sleep eller vad nu problemet är...
(går bilen in i deep sleep så kräver det väl mer tid på 12V vid en uppstart innan alla system kommer igång och då även kanske laddning av 12V-batteriet men
deep sleep pgav låg SoC vet jag inte om man kan förutsäga då det snarare verkar hända lite random lixom)
Re: 12 voltsproblem
Bättre sent än aldrigLarsL skrev:Svar typ ett år senare... När bilen har låg laddnivå på huvudbatteriet så stödladdar bilen inte längre 12V batteriet och om det då är dåligt så dör det snabbt och bilen slutar fungera.Bjelke skrev:Skulle du kunna fråga sedan om varför låg SoC skulle vara osäkrare för ett dåligt 12V-batteri? Och isf vid vilken nivå blir det problem?
Men man undrar ju vid vilken nivå det slutar ladda 12V lixom, det måste ju röra sig om löjligt lite ström...
Re: 12 voltsproblem
TeslaBjörn tog upp detta i en av de senare videoklippen där han får batteritorsk. Har för mig att det är när bilen börjar klaga på att msn ska ta sig till närmaste laddare. Detta är nog inte att räkna som löjligt låg kapacitet kvar.
Re: 12 voltsproblem
Jag tänkte mer på att det borde röra sig om löjligt lite ström som behövs för att ladda 12V-batteriet, och då BORDE det funka vid låg kapacitet på stora batteriet, men
det kanske är som Björn gissar och då är det ju inte lika ovanligt att problemsituationen uppstår.
Men visst måste Tesla ha gjort något bättre iom någon update för man hör inte alls lika ofta att 12V-batteriet gett upp längre?
Nästan så att man blir sugen på att sätta en logger på 12V och kolla hur/när det laddas, men då hade man ju egentligen även velat haft något att jämföra
med från förr också...
Re: 12 voltsproblem
Var tydligen ett sämre sorts 12V batteri 2013-2015 ungefär.
Fick nytt i min vintern 2016 och då sa de något om att de numera sätter i ett ”bättre batteri” just för att slippa byta så ofta.
Har för mig om att jag läst att byte av 12V batteri ingick i årlig service, åtminstone förr?
Nu: BMW i4 eDrive40 700mil, Seat Mii 800mil, Tesla Roadster 250mil.
Fd:MG5 850mil, MYLR 900mil, Kia EV6+ 1500mil, Skoda Enyaq iV80 2000mil, VW ID3 1100mil, Kia eNiro 3700mil, X100D-17 1500mil, P85-14 3000mil, 4xe-Golf 8700mil, e-up 2000mil
Re: 12 voltsproblem
Vi har en S85D från mars 2016, kört 15’ mil nu och har aldrig haft nåt batteritrassel. Tänker att jag byter batteri så småningom, till ett Optima (tror det heter så) torrbatteri som används i tex ambulanser (har jag för mig... Får kolla upp det...)
Re: 12 voltsproblem
Idag så fick jag meddeland om att 12V batteriet var dåligt och måste bytas. Har en S85, dec-14 som gått 10100. Har förlängt garantin. Har mailat SC och inväntar svar.
Hoppas bytet går fort och billigt.
on order MYP & MSPl
M3LR
MSLR
S85-14(såld)
Leaf 30kWh-16(såld)
Leaf 24kWh-12(såld)
Hembränt T-bränsle: https://monitoringpublic.solaredge.com/ ... /dashboard
M3LR
MSLR
S85-14(såld)
Leaf 30kWh-16(såld)
Leaf 24kWh-12(såld)
Re: 12 voltsproblem
Det verkar många med samma problem, jag fick mitt meddelande igår, men är det någon som har bytt batteriet själv? och i så fall var köptes batteriet?
Re: 12 voltsproblem
Fick det bytt på SC i infracity idag. Kostade 2225:-.
on order MYP & MSPl
M3LR
MSLR
S85-14(såld)
Leaf 30kWh-16(såld)
Leaf 24kWh-12(såld)
M3LR
MSLR
S85-14(såld)
Leaf 30kWh-16(såld)
Leaf 24kWh-12(såld)
- Tars
Re: 12 voltsproblem
Va inte farligt dyrt.clecab skrev:Fick det bytt på SC i infracity idag. Kostade 2225:-.
Är inne på Tesla nr 22 som jag brukat, orkar inte skriva ner alla så det får bli en siffra.
Just nu ingen tesla....
https://lazystore.se/products/white-mid ... 913d&_ss=r
Re: 12 voltsproblem
Dock så bokade de in en hel timme för att vara säkra på att hinna. De sa sedan att de kan byta på knappt 30min.
Dock tog det 1.45... Vet inte riktigt vad de gjorde. Det blev kanske lunch eller så.
on order MYP & MSPl
M3LR
MSLR
S85-14(såld)
Leaf 30kWh-16(såld)
Leaf 24kWh-12(såld)
M3LR
MSLR
S85-14(såld)
Leaf 30kWh-16(såld)
Leaf 24kWh-12(såld)
- SweNilsson
Re: 12 voltsproblem
Har min inne för byte nu. -14 P85 @7000 mil, men med förlängd garanti som tur är.
Fick meddelandet i mellandagarna om att byta batteri och jag fick känslan av att problemet hänger ihop med att uppdateringen till prutt-mjukvaran ändrade mina inställningar till strömsparläge. Kan det vara så att 12-voltsbatteriet laddas mindre med den inställningen?
Re: 12 voltsproblem
Mitt 12V-batteri var bara ett år när det lade av i min Model S100D. Han se meddelandet kort i displayen att service var nödvändigt innan allt dog.
Nu gick det inte att rebota bilen och den var låst i parkeringsläge. Tesla center sa att jag måste ta bärgning och då den ändå skulle på ettårskontroll kunde den lika gärna åka med bärgningsbil. Hur gjorde vi, jo vi satte en ctek-laddare och lyckades starta upp skärmen kort för att få den i Tow-mode innan skärmen dog igen och sen gick den att rulla så att vi kunde dra upp den på en bärgare, annars hade bärgningsfirman varit tvungen att lyfta på den enligt Tesla. Krångligt då med specialbärgare.
Dåligt att ett 12V-batteri bara håller ett år, måste varit dålig kvalité på batterierna man monterat från början.
Re: 12 voltsproblem
Hej, vilken typ o ampere timmar är det på 12 v batteriet samt yttre mått?
Kan man köpa på Biltemas?!
- Jonathanerik_77
Re: 12 voltsproblem
Vad jag har hört så blir det ramaskri från Tesla om dem märker det när du besöker ett SC. Dem verkar totalvägra att göra något på bilen förrän ett originalbatteri från Tesla sitter i bilen. Tror Tesla använder AGM batterier för 12V så det är inte de gamla vanliga startbatterierna.Mio skrev:Hej, vilken typ o ampere timmar är det på 12 v batteriet samt yttre mått?
