Har du en dashcam?
I denna tråden så har vi endast omröstningar och här kan alla skapa en omröstning
Har du en dashcam?
Ja, jag har en dashcam monterad.
45
47%
Nej, jag har ingen dashcam monterad.
51
53%
Antal röster : 96
Re: Har du en dashcam?
Inläggav Teslaägare vinothkannan » 09 maj 2018 11:24
Oh thanks Mattias.. I will give a try and wait for your pictures.
https://www.kjell.com/se/sortiment/dato ... tar-p98847
can i use this instead ..? will it work..?
vinothkannan
Inläggav Teslaägare mattiasottosson » 09 maj 2018 21:27
vinothkannan skrev:Oh thanks Mattias.. I will give a try and wait for your pictures.
I actually bought that too, but unfortunately it won't work since one of the females from the Y-split only have three cables, and it dosen't match the once you need from the original cable.
I forgot that i actually taped everything together in an ugly hidden mess, so I'm afraid that the pictures won't help really.
Two things that will make your live easier when installing the rear cam though:
1. Buy spare blue clips, it's very easy to break them when removing the rear trim pieces. SC has them, or you can go with these:
https://www.navringar.se/plastclips/toyota/plastclips-pl-2064
2. Sand down the rear cable, making it a bit smaller, round and much easier to pull it through tight spaces.
3. Skip the middle clip of the right side trim panel and pull the rear cable through there, instead of going the whole way round the trunk as daerik does. Then you don't have to remove that big trim piece.
If you're lucky, you can pull the cable trough that tiny space that's along the top trim piece in the top of the trunk, but the cable gets stuck very easliy. Mine did, and it was a pain to set it free.
S75D (uncorked), pano, midnight silver. | Model 3 reserverad 2016-03-31
http://ts.la/mattias5218 -> 9000kr rabatt + Fri supercharging.
mattiasottosson
Inläggav Teslaägare mattiasottosson » 09 maj 2018 21:43
mattiasottosson
Inläggav Teslaägare vinothkannan » 09 maj 2018 22:55
Tack så mycket mattias.. :-)
vinothkannan
Inläggav Teslaägare HelectriC » 09 maj 2018 22:58
Eller så gör du som jag och borrar ett litet hål bredvid den gula kontakten och tar den därigenom, det förenklar väldigt när bakre kameran ska monteras.
Model S P75D -17
eGolf 300km -18
Jaguar iPace -18
Model S 85 -15
eGolf 190km -15
Hyundai Kona EV (lev. jan-19)
Model 3 LR (lev. feb-19)
VW I.D., Byton, BMW iX3, DS3 Crossback
Inläggav Teslaägare vinothkannan » 13 maj 2018 22:08
hej..
I managed to get the power supply..once and later on i didnt get any 12V power ...Any idea wat cud have went wrong..?
vinothkannan
Inläggav Teslaägare vinothkannan » 14 maj 2018 23:15
I have made the connections as per Derek from YouTube. I was able to get 12V once and later I replaced with new wires since I made bad insulation to the wires.
But I don’t get any power for my BlackVue
vinothkannan
Inläggav Teslaägare helix » 14 maj 2018 23:20
Det här var en ganska trevlig lösning för alla som har en Blackvue. Blir en integrerad och diskret installation!
https://tesland.com/en/product/blackvue ... for-tesla/
Kanske någon här med 3d-printer som kan göra lite business :)
Här visar DaErik hur man installerar samt hur resultatet blir
helix
Inläggav Teslaägare Bjelke » 15 maj 2018 10:06
Vet inte om det finns någon CAD-modell på den där men även om det finns eller ritas upp så blir inte kvaliteten och finish lika bra med 3D-printat,
fast visst vore det lite ballt ;) :mrgreen:
Även jag har en refferallänk och den är http://ts.la/mikael1178
Använd denna och få lite mer fri Supercharging.
Inläggav Teslaägare vinothkannan » 15 maj 2018 10:18
jag har en fråga...!!
Strömförsörjningen bakom backspegeln är konstant som OBD..?
vinothkannan
FöregåendeNästa
Återgå till Omröstningar
Vilka är online
Användare som besöker denna kategori: Inga registrerade användare och 5 gäster
