Re: Problem med homelink
Postat: 30 sep 2020 18:23
Vet någon om Tesla fått ordning på problemet (för model 3)?
Jag har Aperto med "pearl twin" fjärr, den verkar vara 922 MHz, men fick det inte att fungera i något av HomeLink lägena (Standard/D/UR)
JFL skrev:Har ni testat detta?
"Sommer evo+/Pearl 922MHz, Sommer 310MHz (TX03-310 on the back of the transmitter), and Direct Drive 310MHz (blue buttons on the transmitter) require use of the “D-Mode” for HomeLink programming. Currently, in Model S and Model X vehicles, this mode (labeled as “Default Receiver”) can be found under the “Change Transmit Mode” option in the HomeLink Settings screen. Switching to this mode, then following the on-screen instructions, should enable you to program your evo+/Pearl 922MHz, Sommer 310MHz, and Direct Drive 310MHz garage door openers. However, this mode is not currently available on Model 3 vehicles. For resolution of this issue please contact Tesla Customer Service at 1-888-518-3752, or Sommer support at 877-766-6607. Tesla is working to resolve this issue."
