Rivian
Re: Rivian
Verkar vara en riktigt bra bil:
Re: Rivian
Bara lovord för Rivian.
Re: Rivian
https://www.motortrend.com/features/202 ... -off-road/
Shocker: 2022 Rivian R1T Proves Electricity Is Better Than Gasoline for Off-Roading.
Why the Rivian R1T makes it difficult to return to conventional gasoline vehicles for overland adventures.
If you asked me to design my ideal off-roader prior to MotorTrend's 2022 rivian r1t Trans-America Trail overlanding expedition, I would have called for a powerful, torquey V-8, real four-wheel drive with a two-speed transfer case, locking differentials, and a trick adaptive suspension. You know, something like the 2021 Ram 1500 TRX we took along as our support rig for our Trans-America Trail journey. But after off-roading our long-term-test Ram back-to-back with the new rivian r1t electric pickup truck, I doubt I will be able to find the same enjoyment that I once did in off-roading a traditional gasoline-powered vehicle. Surprised as I am to write this, electric motors are just plain better off-road hardware than the internal combustion engine (ICE).
Re: Rivian
Grattis vilken upptäckt
Ganska givet skulle jag säga, iaf om man kört eldrivet ett tag
Re: Rivian
Rivian i krock på parkeringsplats, förarmisstag enligt Rivian. https://www.rivianownersforum.com/threa ... -lot.1746/
Elbilist sedan 2014
- carl-pedal
Re: Rivian
Aj då!
Hoppas jag ser fel eller är det hål i asfalten? Skaplig parkeringskrock isf...
Model YLR svart beställd 13/1
Model 3 SR+ vit - 21
Model S90 2015 RWD såld
Re: Rivian
Tror det är en pöl med olja från Explorer övertäckt med något bråtecarl-pedal skrev:Aj då!
Re: Rivian
Något verkar ha gått snett iaf...carl-pedal skrev:Aj då!
Elbilist sedan 2014
Re: Rivian
Klintan skrev:Något verkar ha gått snett iaf...carl-pedal skrev:Aj då!
Testade terrängkörningsmöjligheterna.
- ChristerSjo
Re: Rivian
Men nådde inte hela vägen.....backe skrev:Klintan skrev:Något verkar ha gått snett iaf...carl-pedal skrev:Aj då!
M3 LR Drag 2019 Såld
M3 LR Drag 2023 feb
Zoe 2019 41 kWh
21 kWp solceller.
M3 LR Drag 2023 feb
Zoe 2019 41 kWh
21 kWp solceller.
Re: Rivian
Rivian R1T är tung.
3870kg=8532lbs.
3870kg=8532lbs.
The Rivian R1T Owners Manual hints that the all-electric pickup could essentially be considered a heavy-duty truck. Several details in the Rivian R1T Owners Manual hint at this, but the main one would be the all-electric pickup’s Gross Vehicle Weight Rating (GVWR) of 8,532 lbs.
Re: Rivian
Då kommer den nog inte till Europa om man är tvungen att ha C kort för att köra den.
Re: Rivian
GVWR är ju bruttovikten, curb weight är 2670kg vilket är 1-200kg över model x och nära ford f150 supercrew(4 -dörrs)
Ger ändå möjlighet till +700kg last innan 3,5t
Curb weight = tjänstevikt - förare
Gvwr = totalvikt
Gvwr = totalvikt
Re: Rivian
Några hundra kg hit eller dit, ligger den så pass högt så blir det tight oavsett om den ständigt spekulerade höjningen av behörighet kommer. Man vill ju kunna dra ett ton iaf.
Re: Rivian
Det är väl ett ganska vanligt problem på lite större pickisar med hög tillåten lastvikt. Men får man inte alltid dra 750 kg även om ekipagets sammanlagda vikt då blir över 3.5 ton?dd88 skrev:Några hundra kg hit eller dit, ligger den så pass högt så blir det tight oavsett om den ständigt spekulerade höjningen av behörighet kommer. Man vill ju kunna dra ett ton iaf.
Re: Rivian
Ja, men totalvikten sätts av fordonetsvikt inklusive förare plus hur mycket last man registrerar den för.kallekula skrev:Behörighet på körkort är väl kopplat just till totalvikt.
Re: Rivian
https://www.theverge.com/transportation ... amp-testedIt’s easy to imagine having a blast road-tripping in the R1T. The seats, including the back row, are comfortable, and you won’t have to worry about access to power for phones and computers. The truck is packed with USB-C and 12V ports and even has a few standard 120V outlets (Rivian hasn’t really said whether the truck will be able to power a whole house in an emergency situation, a feature Ford says the F-150 Lightning will have). Plus, there’s tons of dry and lockable storage, from the frunk and gear tunnel to a cubby underneath the rear seat.
Re: Rivian
5k USD i USA.backe skrev:spacecoin skrev:Inbyggt utekök:
Riktigt coolt, undrar vad det tillvalet kommer kosta?
