MG 4 kommer i september
Re: MG 4 kommer i september
The boot was a good size, with a two level floor. No figures were given regarding litre capacity, but it appeared bigger than say Kia Niro Electric.
The dashboard design is well laid out, with a quality fit and finish throughout. Clearly this is a car which has been benchmarked against the iD3, but I'd objectively say that this feels more premium.
I have been told by an MG UK engineer that the CCS charging speed on the 51kWh variant is around 90-100kW, and on the 64kWh version it is 120-130kW peak.
The quality of the finish was very impressive. This was in Trophy specification, in the new Camden Grey paint colour, with a 64kWh battery. Interior space has been maximised by using a long wheelbase (the MG4 wheelbase is only 15mm shorter than the MG HS). This gives shorter overhangs, with more passenger space compared to traditionally proportioned cars.
https://www.mgevs.com/threads/mg4-first ... ions.6798/
MG 4
Price from £20,000 (est) Sharp electric hatch has a range of up to 281 miles, and a rapid 443bhp version is on the way
WHEN OLEKSANDR USYK defeated then current heavyweight boxing champion Anthony Joshua last year, it rather shook up the boxing scene. And now, title outsider, MG hopes to do similar in the small electric car class, with its new MG 4 hatchback. A rival to the likes of the Cupra Born and Volkswagen ID 3, the MG 4 pairs a single 167bhp electric motor with a 51kWh battery, to provide an official range of 218 miles in entry-level form.
A more powerful, 201bhp motor with a 64kWh battery will also be offered, and this will give an official range of up to 281 miles farther than the Nissan Leaf and most versions of the Born can take you.
A performance version of the MG 4 will also be available in the future. It'll share the 64kWh battery of the regular version, but dual electric motors will give the car four wheel drive and provide 443bhp in total. As a result, the hottest MG 4 is claimed to sprint from 0-62mph in just 3.8sec, making it quicker than the most powerful versions of the Born and ID 3.
The 51kWh model has a maximum charging rate of 100KW, while the 64kWh versions can charge at a higher rate of 125kW. At this rate, a 10-80% charge should take around half an hour if you can find a suitably powerful public charging point.
The MG 4 uses all-new underpinnings. Thanks to the way the battery is accommodated within the car's body. impressive interior space is promised, along with agile handling
The MG 4 is more individually styled than previous MG models, so it should stand apart from rivals that include the Hyundai Kona Electric and Peugeot e-208. Inside, the MG 4 gets a sleek central infotainment touchscreen that rests atop the dashboard, along with a digital instrument panel behind the steering wheel. Like its siblings, the MG 4 is likely to offer the usual amenities, such as a DAB radio, Bluetooth and sat-nav, as well as wireless Apple CarPlay and Android Auto smartphone mirroring.
While prices haven't yet been announced, the MG 4 is expected to start at around £20,000. That's a fair bit cheaper than the Born, e-208 and ID 3.
MG 4 kostar från 25.995 pund i England.
https://www.mg.co.uk/
snowman
Inlägg av snowman »
Intressant med priserna.
SE (51kWh battery och mindre utrustning) £25,995.00
Throphy Long range (64kWh och verkar fullutrustad) £31,495.00
Så med lite tur kan en med stora batteriet och nära fullutrustad kosta runt 380-400.000 i Sverige.
Hoppas det sätter lite press på andra tillverkare så priserna kommer ner.
Med största batteriet kostar MG 4
415.000kr.
https://www.mgmotor.eu/sv-SE/model/mg4#form
J_Pettersson
Ort: Tibber referral kod https://invite.tibber.com/afr8vwfg
Inlägg av J_Pettersson »
415.000kr.
När kommer den till Sverige och har man mer specifikationer vad det är för utrustning?
415.000kr.
Fast MG ZS EV, en större bil med samma räckvidd, kostar från 413 tusen.
J_Pettersson
415.000kr.
Fast, långt ifrån lika snygg enligt min åsikt.
mindfeeder
Inlägg av mindfeeder »
415.000kr.
Jag läser "från pris 415.000:-", tolkar detta som det lägsta instegs-priset. Ett rejält steg upp från UK's 320.000:-
Tolkar jag det fel?
415.000kr.
Tolkar jag det fel?
Initialt säljer dom med största batteriet. Efter ett tag kommer det mindre batteriet.
J_Pettersson
415.000kr.
Tolkar jag det fel?
Lade en förbeställning och får se vad de säger när de återkommer. Förbeställningen var ej bindande.
MG verkar ha kopplat greppet om att vara Sveriges mest sålda elbilsmärke.
MG leder försäljningen sedan 1 juli.
https://www.car.info/sv-se/stats?from=2 ... registered
Edward123
Inlägg av Edward123 »
Fortfarande inte lärt dig skillnaden på försäljning och registrering?
Blipblop
Inlägg av Blipblop »
Sveriges billigaste vettiga elbil mg5 har nog hjälpt till? Zs ev också då…
Leyer
Inlägg av Leyer »
Just nu är ju problemet hur många de lyckas tillverka, inte hur många de lyckas sälja.
Bilagan MG försäljning.jpg finns inte längre
Med tanke på att MG gick ut förra året och sa att det skulle vara det största märket av laddbara bilar under hela 2022, och inte bara sista halvåret så har de en hel del att jobba på.
alvenzo
Inlägg av alvenzo »
Det här året har väl inte blivit som planerat för nån tillverkare? Problemet för MG, och de flesta andra för den delen, är inte försäljning utan leverans. Dessa siffror betyder inget gentemot tidigare satta mål.
Det har du förvisso helt rätt i men har man följt Zalman3s inlägg så fick man redan 2018 höra att de europeiska tillverkarna bara pratade, de kinesiska tillverkarna kunde däremot leverera elbilar i stora mängder. De europeiska tillverkarna skulle inte ha en chans mot den floden av billiga elbilar som skulle komma från kina. Nu flera år senare så lyfts det till skyarna ifall en kinesisk modell lyckas bli den bäst säljande elbilen i ett land under en enstaka månad, att lyckas bli en av de populäraste modellerna över tid verkar fortfarande inte ha hänt.
Visst, kinesiska tillverkare har inte haft lätt med lockdown mm men det har de europeiska tillverkarna inte heller.
Och MG har nu tappat greppet igen då volkswagen har levererat fler elbilar senaste dagarna. Ska bli intressant hur det utvecklas framöver.
MG 4 AWD är på gång.
This flagship version of the MG 4 is powered by a dual-motor all-wheel drive setup producing 330kW of power and 600Nm of torque.
https://www.carexpert.com.au/car-news/2 ... d-in-china
NiklasTesla
Inlägg av NiklasTesla »
Med ett större batteri och V2G teknik och drag hade den den varit intressant för mina behov.
Blir Model 3 LR några år till känns det som samt MVH
Blipblop
Jag tycker den här är intressant, men med tanke på hur få som fått sina mg5 hittills så antar jag att vi får vänta ett tag till…
MG 4 har tagit till tunga vapen för att ha en bättre lösning än Teslas FSD! :lol:
Från tyska sidan med Google translate.
Dafro
Inlägg av Dafro »
Nu blev den ju faktiskt intressant på riktigt. :D :D :lol:
27,8 kWp solceller
