M3 från Kina säljs i Europa.
friednice
Re: M3 från Kina säljs i Europa.
Inlägg av friednice »
I can certainly answer all of that tomorrow evening apart from the charging. Maybe over the weekend if I get a chance to supercharge.
iohrlund
Inlägg av iohrlund »
At what time will you pick up your car?
sebiva
Inlägg av sebiva »
Nu börjar det trilla in rapporter på tyska forumet:
https://tff-forum.de/t/m3-sr-bestellung ... 83972/2329
Den som hittills skrivit har både nya strålkastare och den gamla (större) frunken vilket låter lovande!
Likenoother
Inlägg av Likenoother »
Intressant vilka uppdateringar kina bilen har gentemot den gamla ....
Någon som sitter på mer info ?
Beställt : Tesla model 3 Performance -2021
Ägt : Volkswagen Passat -18 Gte
Klintan
Inlägg av Klintan »
Verkar vara USB-C fram och bak, nya scrollhjulen på ratten.
Edit: verkar ej vara nya scrollhjulen enligt uppdatering på TFF.
Elbilist sedan 2014
Likenoother
Spännande :D
Man kanske ska byta ner sig till en kina bil ;)
friednice
I collected my SR+ in Amsterdam today.
Basically its the late 2020 spec with the LFP battery pack. USB C but no doubled glazed glass or any other 2021 specs (a little disappointed about the glass but I already presumed the rest.)
I supercharged from about 18% - 80% in 1hr 20 was getting 264km/hr at the start but that levelled to about 184 at 35% and then to about 175 through 50% and at 80% i was getting 133 and when I unplugged it dropped to 70 for some reason.
I'm not sure how that compares to the none LFP version.
esteen
Inlägg av esteen »
Thank you!
To be honest the charging speed was really slow, I was expecting about half the time according to a Chinese test and that was already slow.
But was the battery warm when you arrived?
Did you set the Supercharger in the navigator so it preheated?
Does the var have the new headlight and the new steering wheel?
friednice
The car pre-heated for the 10km drive to the supercharger.
Steering wheel is the old style with the rubber dials.
No idea how to check the headlights
jeppe_sthlm
Inlägg av jeppe_sthlm »
Ok - battery won’t be warm in 10km, so hopefully the figures will a bit better than that.
Big thanks for reporting back!
Model S P85+ med AP
Model S Standard Range Raven
jeppe_sthlm
Check this video for the non-LPF SR+
Note that he is charging on Ionity, which can give up to 250kW.
A normal Tesla V2 charger is maxing out on around 145kW if you are not sharing stalls with another car. That requires a warm
battery though.
Model S P85+ med AP
friednice
Well based on that I was getting a really slow charging speed. :(
jeppe_sthlm
Well, first of all your battery was not warm in 10 minutes, which is most likely a big factor.
If you’d get around 100kW on low SoC - you still have a faster charging car than most non-Tesla EV’s. The car is also one of the most efficient, so it should give you pretty short charging stops anyway.
It most likely charges faster than my old Model S anyway.
Next - if you charge at home, it doesn’t have any effect.
Model S P85+ med AP
With an OK warm battery I normally do a charge from 20% to 80%, on my longe range (the larger battery pack version) model 3 AWD, in about 21-24 minutes on a 150 kW chargingstation (both Tesla and non-Tesla).
M3LR
Jontez
Inlägg av Jontez »
Ok, so you maximum was 264km/hr, its about 36kW.... Im woundering how fast (or slow?) it will be with a pre-heated battery!
Model 3 LR 2021 Midnight/Black SÅLD
Model Y Performance 2022 Black/Black
r33z
Inlägg av r33z »
En video på leverans av SR+ från Kina
TM3 SR+ MiC
Klintan
Inlägg av Klintan »
Om man läser tyskarnas rapporter så verkar inte alla fått nya strålkastare, verkar vara skillnad beroende på tillverkningsdatum, runt 20/10 tror jag det blev nya strålkastare.
Många rapporterar långsam SuC, 20-30 kW. En förare fick 80 kW efter att ha kört 100 km med förbrukning över 200, så batteriet behöver bli varmt för att laddas någorlunda snabbt.
https://tff-forum.de/t/m3-sr-bestellung ... 83972/2785
Kuriosa är att tyskarna verkar ha fått 12 mån premium connectivity trots att det borde vara 30 dagar.
Elbilist sedan 2014
jeppe_sthlm
Nu har jag inte läst igenom tråden (min 25 år gamla skoltyska är lite knackig), men de kurvor som låg i där såg inte jätteimponerande ut. Inte så mycket snabbare än mitt nerfade 85-pack, men man kanske inte ska dra alltför stora växlar än.
Finns ju en möjlighet att man vill samla på sig mer data innan man vågar släppa på mer hastighet.
Håller nog dock på en eventuell beställning tills det finns mer fakta på bordet.
Model S P85+ med AP
kenjon
Referralkod: ts.la/kent 76750
Inlägg av kenjon »
Är det inte 30 dagar Premium Connectivity på SR och 1 år på LR/P?
Model Y LR 2021 blå
Beställt Model Y P mars 2022 blå (estimerat aug-sept 2023) Avbeställd
Bokat Cybertruck
Från Kina levereras endast Model 3 SR+.
Klintan
Inlägg av Klintan »
Verkar när man läser TFF som att man tror att en del av problemen kan vara att batteriet behöver balanseras och kalibreras. Nya ägare har fått att laddningen stannat med 0 kW vid 89% på SuC. Jag väntar till fler rapporter om laddhastighet vid låga utomhustemperaturer innan jag törs beställa en MIC M3.
Däremot verkar de vara överens om att ljuddämpningen är mycket bättre.
Elbilist sedan 2014
friednice
My China SR+ only charged to 93% today. It was the first time I tried to fully charge it.
Any ideas why? The range was also only at 385km.
How does the car calibrate this?
NiklasTesla
Inlägg av NiklasTesla »
Kan det helt enkelt vara så att dom nya ägarna inte känner till hur laddnivån ställs in på 100% i bilens meny?
NiklasTesla
Go to charging settings. There you can raise the charge level to 100%
