Homelink
Postat: 04 okt 2017 15:43
av vinothkannan
Does anyone in sweden has installed Automatic Door opening for the Garage with Tesla model-S or ex. ..?
Any guide..available...!
Re: Homelink
Postat: 05 okt 2017 21:37
av Gustafsson
Just follow the instructions in the manual or the on-screen instructions in the car.
Re: Homelink
Postat: 05 okt 2017 21:43
av Feddan
Here's Homelink's official guide:
http://www.homelink.com/tesla
Re: Homelink
Postat: 06 okt 2017 06:57
av AGCF
I had a marantec 868 Mhz opener but had to change to 433 Mhz to get homelink to work. Homelink doesn't support frequencies over 433 Mhz
Re: Homelink
Postat: 09 okt 2017 13:18
av vinothkannan
I have Hörman Promatic 868Mhz... supplied from the House builder.
Any suggestions..! Should I replace with a lower frequency..?
Re: Homelink
Postat: 09 okt 2017 14:13
av JonasH
Add a 433 MHz receiver to the Promatic and you will be ok. You allso need a 433 MHz remote to program the car.
Re: Homelink
Postat: 10 okt 2017 10:50
av vinothkannan
Re: Homelink
Postat: 10 okt 2017 11:07
av ALDA
I got this one on Ebay, has been working flawlessly for a year now:
http://www.ebay.com/itm/1x-RF-Remote-Co ... X4jBO#rwid
It doesnt come with instructions, some wiring requiered (it connects to your garage door openers outlet for fixed wall remote).
Re: Homelink
Postat: 10 okt 2017 12:51
av JonasH
I got mine from Hornbach. They ordered it from Hörmann and I got it in a couple of days.
Re: Homelink
Postat: 10 okt 2017 15:36
av vinothkannan
Thanks a lot for your suggestions.. I called hornbach.. they will place an order at Hörman.
Soon I will post a Picture as a honour with Homelink activated garage
Re: Homelink
Postat: 25 nov 2017 16:12
av lano
I have a Liftmaster LM60K that operates on 433,92 Mhz that works fine with homelink in my Tesla model S.
I also have a Sommer 4796V000 that operates on 868,8 Mhz and that also works.
Re: Homelink
Postat: 04 dec 2017 13:34
av vinothkannan
Could anyone help me how to fix this on Horman Promatic Garage opener..
There is no installation diagram to fix this
Re: Homelink
Postat: 07 dec 2017 13:56
av vinothkannan
JonasH skrev:I got mine from Hornbach. They ordered it from Hörmann and I got it in a couple of days.
Is it the same one you bought..?
Re: Homelink
Postat: 10 jun 2019 12:13
av areskoug
vinothkannan skrev:Could anyone help me how to fix this on Horman Promatic Garage opener..
Did you manage to connect this? If so, how? Have the same opener and stuck without instructions
Re: Homelink
Postat: 11 jun 2019 00:35
av Kimera
Har samma problem med min port att den inte funkar. Ska man löda på den 433mhz boxen till sin befintliga eller hur är det tänkt?
Re: Homelink
Postat: 27 jun 2023 21:25
av Rennwagen
Väcker upp denna tråd. Jag lyckades få min remote till garagporten (Crawfoord) att funka med min förra Model S men lyckas inte med min nya 2023. Någon som vet hur det funkar? Jag följer instruktionen för Homelink i bilen men när jag står framför bilen och aktiverar knappen på fjärrkontrollen för att öppna porten så skall bilens framljus blinka till när de känner signalen och det gör de inte. Vet inte varför den inte känner igen signalen?
Re: Homelink
Postat: 28 jun 2023 08:30
av Jojo
Rennwagen skrev: ↑27 jun 2023 21:25
Det var ungefär likadant för mig, fast jag inte bytte bil utan garageport. Homelink fungerade med den äldre, dock ej den nyare, hur man än försökte. Det var någon ändring på frekvensbandet, vill jag minnas, och det senare stöddes inte av Homelink. Man skulle kunna köpa till en transponder eller liknande, då skulle det fungera (enligt installatören). Jag struntade dock i investeringen och använde fjärrkontrollen, som följde med porten.
