Request for Information of EV charging Pattern
Postat: 05 jul 2018 11:26
av TiborBlomhall
Vi har fått följande förfrågan:
We are master students from KTH who are majoring in Electrical Power Engineering. Currently, we are doing a project regarding residential electricity consumption, with the possible variations occurring due to electrical vehicle charging pattern.
We searched online and found "Tesla Club Sweden" website. We thought you might be interested in participating in such social research and survey. We request you to kindly participate and encourage your club members to participate. We will appreciate and keep your response anonymous. This is part of a study project and the intention is to study the grid stability as a result of EV.
1. How regularly do you charge your EV battery? What time of the day you charge the EV?
2. How much do you pay for charging your EV per month? in other words, how much change did you see in your electricity bill after getting an EV?
3. Would you be willing to participate in a project including EV charge control?
It would be great to have your insight on these problem through answering these question, we would appreciate if we can get more in touch with you to learn more about the EV owners prospective.
Ni som kan tänka er ingå i deras studie kan kontakta dem på
kgsharma@kth.se
Re: Request for Information of EV charging Pattern
Postat: 05 jul 2018 11:28
av TiborBlomhall
Och själv svarar jag:
1. Jag laddar varje natt, startar kl 23 med timer.
2. Ca 300:- per månad.
Postat: 05 jul 2018 11:29
av evilirish
Jag blir lite nyfiken på vad "EV charge control" kan vara?
Postat: 05 jul 2018 11:38
av chaffis75
Varje dag när batteriet är under ca 85%. På sommaren startar när jag kommer hem, på vintern när elpatronen är på i pannan så efter 20 på kvällen (med timer i bilen) så vi har hunnit laga mat så slipper huvudsäkringen gå.
Lite osäker men jag räknar runt 200kr/månad
Ja lite beroende på vad som ska göras...
Postat: 05 jul 2018 11:41
Vi kopplar in bilarna varje dag när vi kommer hem. Laddning startas med timer på natten.
Teslan börjar ladda kl 0:00.
e-Golfen har omvänd timer, dvs den är inställd så att den är klar med laddning kl 7:00.
Beroende på årstid och väderlek startas laddningen redan vid ankomst för att kunna utnyttja egenproducerad solel maximalt.
Elräkningen för laddning per månad varierar mellan 0:- (egen solel på sommarn) och upp till 400:- (köpt el på vintern).
Postat: 05 jul 2018 11:42
av Arild
Kul studie och bra att problemställningen belyses. Min gode vän på Svenska Kraftnät är seriöst bekymrad över övergången till elbilar med laddning hemma. De förväntar sig en kraftig ökning av elkonsumtion när ägarna laddar hemma samtidigt med middagslagning. När jag berättar att elbilsägare är förnuftiga och börjar sin laddning under dygnets lugna timmar, tror han mig inte.
Mina svar:
1. Laddning varje natt, kl. 00.05.
2. 180 kr./månad.
Postat: 05 jul 2018 11:47
av chaffis75
Arild skrev:Kul studie och bra att problemställningen belyses. Min gode vän på Svenska Kraftnät är seriöst bekymrad över övergången till elbilar med laddning hemma. De förväntar sig en kraftig ökning av elkonsumtion när ägarna laddar hemma samtidigt med middagslagning. När jag berättar att elbilsägare är förnuftiga och börjar sin laddning under dygnets lugna timmar, tror han mig inte.
Mina svar:
2. 180 kr./månad.
Om leaf laddaren hade varit 3 fas (och mer effekt såklart) hade jag nog också satt den till runt midnatt men kl 20 är bra för vår del eftersom då blir den klar till morgonen även när batteriet är nästan helt tomt...
Postat: 05 jul 2018 11:48
1. Normalt sett startar min laddning vid kl 2 och sedan laddar jag runt 8-10 kWh per vardag och kanske runt 230 kWh per månad.
2. Eftersom jag har egen solcellsel så kan man räkna lite olika på vad kostnaden blir även ifall jag laddar när solcellerna inte leverera något. Kostnaden blir väl kanske runt 100-200 kr per månad.
3. Ja men beror på.
Postat: 05 jul 2018 11:51
Antar att man ska maila för att vara med... men postar svaren här också.
I plugg in my car when I get home at around 18.00. The car is finished charging at about midnight. I have currently no insensitive to charge at other times.
From the car I have calculated that it’s about 300kr/month. My electric bill is hard to use as I have changed heating system during this time, that effect was a lot more than the car charging.
I would be interested in more information about this before I sign up.
Postat: 05 jul 2018 12:49
av jonas
1. Varje natt kl 03 med 22kW AC.
2. Ca 10 000kWh per år, egen sol som jag räknar med 40öre/kWh för så blir det exakt 10000/12x0,4kr/mån eller drygt 330kr/mån.
3. Ja speciellt om vi talar DC laddning. Då kan jag använda solelen direkt.
Postat: 05 jul 2018 13:34
av Zalman3
Laddar till 99% på Teslas snabbladdare. Laddar på dagtid vid lunch eller middag när jag är ute och reser. Kan inte ladda hemma.
Betalar 0kr för laddning.
Ja.
Postat: 05 jul 2018 14:02
av Engen
1.
Varje dag när batteriet är under ca 60%. På sommaren startar laddningen när jag kommer hem, på vintern kl 00.00 med timer i bilen.
2.
Ca 200kr/månad med nuvarande körmönster.
3.
Ja.
Postat: 05 jul 2018 18:46
1. Brukar plugga i när det är under 50%. Är besvärligt hemma eftersom jag blockerar 4 grannar.
2. Cirka 200kr/mån (obs elen kostar drygt 1.5kr/kWh för ett radhus i Stockholm med 3x20A)
3. Beror på vad det är
Postat: 05 jul 2018 20:13
av LarsA
Har två elbilar därav tillägg a och b
1a. Var annan eller tredje dag när batterinivån når 60%. Från ca 18:00 med ca 1,5kW(7A).
1b. Var annan eller tredje dag (oftast 70/80 till 100%). Från ca 12:00 med ca 1,5kW(7A).
2a. 400:-/månad inkl. nätavgift.
2b. 300:-/månad inkl. nätavgift.
3. Visst men svårt då lite belysning även ligger på samma säkring.
Postat: 05 jul 2018 20:48
av chpaulin
- Every day, usally start at 02:00 since the electricity is cheapest then (using 3-phase), done in 2-3h
- ~300SEK
- Yes
