[SÅLD]OBD2/CAN kabel
Postat: 19 apr 2019 12:14
Eftersom planen att köpa en begagnad Model S slutade med beställning av en ny lagerbil så har jag en OBD2/CAN kabel för bilar tillverkade innan september 2015 över.
Kostade mig 600:- (alltså 2,5 gånger priset för själva kabeln!) innan den var framme. Bjud gärna något liknande
Så här skrev IdeaFab i sin annons för den på etsy.com:
OBD2/CAN adapter cable that allows you to talk to CAN bus 3 on the Model S/X. You would use this cable to connect a supported OBD2/CAN reader (ELM327, Blue Tooth, Wifi, Serial, USB, etc). The cable is 1ft long and is internally shielded for more accurate data. All cables are tested prior to shipping.
Popular apps to use this cable include the amazing TM-Spy (iOS app is coming):
https://play.google.com/store/apps/deta ... rbo3.TMSpy
Tons of other OBD2/CAN apps are out there, and not much information is given about the car through the car's "normal" OBD2 port under the dash. With a slight pull down of the cubby shelf, you can access the same OBD2/CAN port the Service Center uses all the time. Only pull the front of the shelf down, until you can reach your hand back and grab the cable. The port will pull from the left and you connect this adapter to it, along with the OBD2/CAN reader.
