Nissan Leaf / e-NV200 range extender
Postat: 17 jan 2020 13:35
av Zalman3
Är det nån som provat att chippa sin Leaf?
Mellan 5 till 15% längre räckvidd utlovas.
Nissan Leaf / e-NV200 range extender and regenerative force improvement – LEAF Box
Leaf Box is a range extender controlling load applied to engine via throttle control. No problems with warranty - undetectable by dealer. It is easy to install, as it uses factory plugs. It delivers following extensions to standard Nissan Leaf:
range extender – it bases on adding „N-mode on demand” (aka glide mode) to D-mode, along with alternative torque delivery strategy (read below). Range extension is around 10% (ECO mode, 24kWh/30kWh battery). With normal mode, Leaf Box is off.
mimic of some functions of "e-pedal" from new Nissan Leaf 2018 is possible.
the regenerative force at D mode can be increased by about 20% (from 20kW to 24kW). If you have the version of Nissan Leaf with B mode - lucky you. But I can have B-mode even in the basic version of Leaf.
max power of Leaf can be increased from 80kW to 83kW (option).
works also for e-NV200
https://evtun.com/leafbox.html?gclid=EA ... gLUUfD_BwE
Re: Nissan Leaf / e-NV200 range extender
Postat: 17 jan 2020 18:42
av LarsA
Finns tester där de inte har upplevt någon förändring i räckvidd.
Googla och du ska finna....
Postat: 17 jan 2020 18:52
av Henrik Torphammar
Finns lite can bus jox att köpa också så bilarna får lite mer kreativa laddkurvor på DC-laddare osv....
