Doors in Winter
Postat: 02 okt 2023 11:00
av swapnilpt005
Hej,
Jag skulle vilja veta om vi kan förhindra att dörren/fönstren fryser under vintern. Jag brukar parkera min bil utanför och vissa minusgrader fryser dörrarna och glaset kommer inte upp/ner förrän vi förvärmt bilen i 15-20 minuter
In English
Hello,
I would like to know if we can prevent the door/windows from getting frozen during winters. I usually park my car outside and on some freezing days the doors get frozen and the glass doesn't come up/down until we preheat the car for 15-20 mins
Re: Doors in Winter
Postat: 02 okt 2023 11:05
av mikebike
Silicone grease on all rubber surfaces, also on the bottom of the side windows.
WD-40 on door handle hinges and on the outside mirrors.
I use this, but it's out of stock:
https://www.biltema.se/bilvard/smorjmed ... 2000030629
EDIT: Jula has a similar product:
https://www.jula.se/catalog/bil-och-gar ... tt-001969/
Re: Doors in Winter
Postat: 02 okt 2023 15:45
av AAKEE
I’ve had had a Model 3 over 3 vinters.
Before that I have a Audi with the same frameless solution for 12 years until today.
I havent really had any issues with frozen windows, so I have not used any substances.
Re: Doors in Winter
Postat: 02 okt 2023 15:48
av fth
I have been told that you should never use silicone products on the rubber seals, so i ordered a silicon free "gummipflege" product that i have been using.
That said, i have never had any issues with the doors/windows freezing during six Swedish winters, neither before or after i started using the "gummipflege" on my seals.
Re: Doors in Winter
Postat: 02 okt 2023 18:21
av AAKEE
fth skrev: ↑02 okt 2023 15:48
Yes, a little of my thinking.
When I was in the armed forces as a diver the one-and-only solution was talc powder or baby powder for all rubber things.
Havent used it on the cars but the Audis rubber strips almost felt like that when new, and to some extent still does.
Re: Doors in Winter
Postat: 02 okt 2023 20:00
av bjelkeman
Both my Model S and Model 3 have had issues when I haven’t preheated long enough. Often after snow, that has melted and frozen again.
I have a special credit card for these occasions. Slide down between the seal and the window so the window isn’t frozen in place, when the door is opened. But haven’t had the window freeze at the top, much. Mostly at the bottom.
Re: Doors in Winter
Postat: 02 okt 2023 21:12
av mikebike
bjelkeman skrev: ↑02 okt 2023 20:00
I think it's easier to be proactive and grease the rubber seals before the winter.
Re: Doors in Winter
Postat: 02 okt 2023 21:57
av bjelkeman
True. But sometimes it froze anyway.
Re: Doors in Winter
Postat: 03 okt 2023 06:09
av mikebike
bjelkeman skrev: ↑02 okt 2023 21:57
The trick for the door window seals is to smear a layer of grease on the lowest cm of the windows with closed doors.
Then open and close the doors a few times.
Finally wipe off any leftover grease.
It's a good thing this came up now, it reminded me that I need to do this routine soon.
Re: Doors in Winter
Postat: 03 okt 2023 07:10
av Jaegaern
This is what I also use.
https://www.amazon.se/gp/product/B0012AW4RO Gummipflege which doesn't grease up the sides and makes windows slide easier when in sub-zero temps.
I also bought this
https://www.amazon.se/gp/product/B000U42S42 which is probably as good, but it smears grease that is highly visible on the windows, even after I wipe off any left overs. Therefor this remains unused and not one of my recommendations. (just included because I didn't know the difference)
Re: Doors in Winter
Postat: 03 okt 2023 07:36
av OvePaHornet
Jaegaern skrev: ↑03 okt 2023 07:10
I also bought this
The first one is more of a ”restorer” (but do also prevent freezing). The second one is the ”best” against freezing, containing vaseline which is GREAT for making rubber seals not freeze and doesn’t harm the paint like silicone. Although it’s way messier than the first one (as mentioned).
Re: Doors in Winter
Postat: 19 okt 2023 11:20
av Wought
Elastic Man
swapnilpt005 skrev: ↑02 okt 2023 11:00
Hej,
In English
Hello,
Applying a silicone spray or WD-40 to the rubber seals around the doors can help prevent them from freezing shut. These products create a protective barrier that repels moisture and prevents ice from forming.
Re: Doors in Winter
Postat: 19 okt 2023 12:09
av Skatbo
Re: Doors in Winter
Postat: 19 okt 2023 13:53
av VilkenElbilBlirDet
Finns det inte också en knapp i appen för att öppna dörrarna?
Hade lätt frysta handtag för någon dag sen, men gick upp rätt lätt den gången.
Re: Doors in Winter
Postat: 19 okt 2023 14:22
av mikebike
VilkenElbilBlirDet skrev: ↑19 okt 2023 13:53
Jo, men det hjälper inte om dörrarna och fönstren frusit fast.
