Appen Remote S
Postat: 16 jul 2016 21:27
Det kom en livlig diskussion gällande inloggnings uppgifter dom vi fortsätter här
The app only communicates with the Tesla servers directly. None of your login information is sent to me. I have no interest in people's login information, and I welcome anyone to sniff the packets sent by the app. This is also easy to do if you have a wifi router that logs the IP addresses that your devices uses. You'll see that the IP addresses it contacts are only Tesla's IP addresses. Your password is stored in the app for the Apple Watch Start Car feature and/or Touch ID feature. If you don't want the app to store any passwords, just don't turn them on. The only reason why I have to store the password is because to start the car, Tesla's API requires the password. Since the Apple Watch doesn't need a password and the Touch ID doesn't have a password input, the app needs the password to send to Tesla's servers. However, nobody has access to that password except for the app, since apps are sandboxed and inaccessible by other apps.
http://www.teslarati.com/tesla-api-cont ... s-model-x/This Mobile API is not documented by Tesla and is not intended to be used by anyone other than Tesla employees. You can use applications Tesla has created that use the API but you’re not supposed to make your own applications using the API.
Fast man har inte ett publikt API. Det är ett reverseenginerat API som tredjepartsapparna använder.chpaulin skrev:Har Tesla några planer på att börja stödja OAuth? Känns ganska standard speciellt om man har ett publikt API å allt.
Ah halvpublikt iaf då man inte säkrat upp accessen med privata cert av något slag. Känns som de nästa vill att andra skall få accessbylund skrev:Fast man har inte ett publikt API. Det är ett reverseenginerat API som tredjepartsapparna använder.chpaulin skrev:Har Tesla några planer på att börja stödja OAuth? Känns ganska standard speciellt om man har ett publikt API å allt.
Vissa funktioner är blockerade, andra inte. T ex går det bra att ändra temperatur på klimatanläggningen under körning, men inte att tuta.djFabbe skrev:Vad mer exakt tillåter API:t att man gör? Kan man tex kontrollera funktioner under färd eller är det blockerat i mjukvara till när fordonet står still? Det senare är ju en viktig fråga vad gäller trafiksäkerheten tänker jag.
Låter ju vettigt. Himla synd att inte röststyrningsknappen på ratten kan mappas mot Siri som på många andra bilar. Ett kort tryck hade tex kunnat aktivera Siri och ett långt den inbyggda röststyrningen. I så fall hade man ju kunnat tex höja/sänka temperatur mm genom rösten genom Remote S under körning - hade varit väldigt smidigt.bylund skrev:Vissa funktioner är blockerade, andra inte. T ex går det bra att ändra temperatur på klimatanläggningen under körning, men inte att tuta.djFabbe skrev:Vad mer exakt tillåter API:t att man gör? Kan man tex kontrollera funktioner under färd eller är det blockerat i mjukvara till när fordonet står still? Det senare är ju en viktig fråga vad gäller trafiksäkerheten tänker jag.
Ett kort tryck har dock redan en funktion: du kommer in i telefonboken och kan ringa direkt från ratten.djFabbe skrev:Låter ju vettigt. Himla synd att inte röststyrningsknappen på ratten kan mappas mot Siri som på många andra bilar. Ett kort tryck hade tex kunnat aktivera Siri och ett långt den inbyggda röststyrningen. I så fall hade man ju kunnat tex höja/sänka temperatur mm genom rösten genom Remote S under körning - hade varit väldigt smidigt.bylund skrev:Vissa funktioner är blockerade, andra inte. T ex går det bra att ändra temperatur på klimatanläggningen under körning, men inte att tuta.djFabbe skrev:Vad mer exakt tillåter API:t att man gör? Kan man tex kontrollera funktioner under färd eller är det blockerat i mjukvara till när fordonet står still? Det senare är ju en viktig fråga vad gäller trafiksäkerheten tänker jag.
Ah. Hade dock varit trevligt om det gick att ställa in ett Siri-mode bland inställningarna för att få Siri att bli förvald samtalspartner när det gäller röststyrning. Tror inte att Tesla varken vill eller kan konkurrera med det breda språkstödet och kvalitén i röststyrningen i iOS/Andriod. Det jag sett demat på plats när det gäller röststyrningen i Model S har verkligen inte imponerat på mig - inte ens i demosituationen fungerar det särskilt bra.HelectriC skrev:Ett kort tryck har dock redan en funktion: du kommer in i telefonboken och kan ringa direkt från ratten.
Nej, där finns det mkt att lära för Tesla, men de grundfunktioner som finns där funkar iaf på min ex. "Navigate tesla service center"djFabbe skrev:Ah. Hade dock varit trevligt om det gick att ställa in ett Siri-mode bland inställningarna för att få Siri att bli förvald samtalspartner när det gäller röststyrning. Tror inte att Tesla varken vill eller kan konkurrera med det breda språkstödet och kvalitén i röststyrningen i iOS/Andriod. Det jag sett demat på plats när det gäller röststyrningen i Model S har verkligen inte imponerat på mig - inte ens i demosituationen fungerar det särskilt bra.HelectriC skrev:Ett kort tryck har dock redan en funktion: du kommer in i telefonboken och kan ringa direkt från ratten.
