Jag har haft ungefär de problem du beskriver. LED-ringen slutade fungera och låset till kabeln krånglade och ville inte låsa upp när jag skulle sätta i laddkabeln. Vill minnas att jag även hade trassel med just luckan och dess stängning.
Jag var inne två vändor till SC innan dom fick ordning på det. Första gången utfördes denna åtgärd:
Corrections: Charge System Inlet General Diagnosis
Confirmed customer concern.
The vehicle has alert "CP_w043_doorPotIrrational"
Found that the vehicles charge port door was out of specification. Performed alignment and calibration of the vehicles charge port door. Validated correct operation after alignment and calibration.
Vehicles charge port is now working as designed.
Det hjälpte tyvärr inte. Andra gången utfördes detta:
Tested and confirmed customer concern. Charge port and charge port latch was not operating as designed. Reviewed logs and found charge port door motor was out of calibration and vehicle could determinate if charge port door was opened or closed. Charge port door needs to be replaced to correct this concern.
Corrections: Charge Port - Single Phase - Motorized
Performed replacement of charge port door and re-calibrated both latch and door sensors. Tested after repair and validated ok.
Sedan dess har det fungerat klockrent.
hej, har samma problem, vad landade prislappen på ungefär?
