Homelink
- vinothkannan
Homelink
Does anyone in sweden has installed Automatic Door opening for the Garage with Tesla model-S or ex. ..?
Any guide..available...!
MX100D-AP3-FSD
- Gustafsson
Re: Homelink
Just follow the instructions in the manual or the on-screen instructions in the car.
Re: Homelink
Here's Homelink's official guide:
http://www.homelink.com/tesla
Re: Homelink
I had a marantec 868 Mhz opener but had to change to 433 Mhz to get homelink to work. Homelink doesn't support frequencies over 433 Mhz
- vinothkannan
Re: Homelink
I have Hörman Promatic 868Mhz... supplied from the House builder.
Any suggestions..! Should I replace with a lower frequency..?
MX100D-AP3-FSD
Re: Homelink
Add a 433 MHz receiver to the Promatic and you will be ok. You allso need a 433 MHz remote to program the car.
TMS LR UltraRed, FSD
- vinothkannan
Re: Homelink
Any shops in sweden or I should buy it online
http://www.garage-door-remotes.co.uk/se ... ormann.htm
MX100D-AP3-FSD
Re: Homelink
I got this one on Ebay, has been working flawlessly for a year now:vinothkannan skrev:Any shops in sweden or I should buy it online
http://www.ebay.com/itm/1x-RF-Remote-Co ... X4jBO#rwid
It doesnt come with instructions, some wiring requiered (it connects to your garage door openers outlet for fixed wall remote).
Tesla Model S60D 2016 - Big Blue
Citroen C-Zero 2015 - Lilla Blå
Re: Homelink
I got mine from Hornbach. They ordered it from Hörmann and I got it in a couple of days.
- vinothkannan
Re: Homelink
Thanks a lot for your suggestions.. I called hornbach.. they will place an order at Hörman.
Soon I will post a Picture as a honour with Homelink activated garage
MX100D-AP3-FSD
Re: Homelink
I have a Liftmaster LM60K that operates on 433,92 Mhz that works fine with homelink in my Tesla model S.
I also have a Sommer 4796V000 that operates on 868,8 Mhz and that also works.
- vinothkannan
Re: Homelink
Could anyone help me how to fix this on Horman Promatic Garage opener..
There is no installation diagram to fix this
MX100D-AP3-FSD
- vinothkannan
Re: Homelink
Is it the same one you bought..?JonasH skrev:I got mine from Hornbach. They ordered it from Hörmann and I got it in a couple of days.
MX100D-AP3-FSD
Re: Homelink
Did you manage to connect this? If so, how? Have the same opener and stuck without instructionsvinothkannan skrev:Could anyone help me how to fix this on Horman Promatic Garage opener..
Model 3 LR AWD - Pearl White 2019.
Re: Homelink
Har samma problem med min port att den inte funkar. Ska man löda på den 433mhz boxen till sin befintliga eller hur är det tänkt?
0-100 ?
Re: Homelink
Väcker upp denna tråd. Jag lyckades få min remote till garagporten (Crawfoord) att funka med min förra Model S men lyckas inte med min nya 2023. Någon som vet hur det funkar? Jag följer instruktionen för Homelink i bilen men när jag står framför bilen och aktiverar knappen på fjärrkontrollen för att öppna porten så skall bilens framljus blinka till när de känner signalen och det gör de inte. Vet inte varför den inte känner igen signalen?
Model S LR 2023, tidigare Model 3 Performance 2022, M3 2021, S90D 2019, 2016
Re: Homelink
Det var ungefär likadant för mig, fast jag inte bytte bil utan garageport. Homelink fungerade med den äldre, dock ej den nyare, hur man än försökte. Det var någon ändring på frekvensbandet, vill jag minnas, och det senare stöddes inte av Homelink. Man skulle kunna köpa till en transponder eller liknande, då skulle det fungera (enligt installatören). Jag struntade dock i investeringen och använde fjärrkontrollen, som följde med porten.Rennwagen skrev: ↑27 jun 2023 21:25Väcker upp denna tråd. Jag lyckades få min remote till garagporten (Crawfoord) att funka med min förra Model S men lyckas inte med min nya 2023. Någon som vet hur det funkar? Jag följer instruktionen för Homelink i bilen men när jag står framför bilen och aktiverar knappen på fjärrkontrollen för att öppna porten så skall bilens framljus blinka till när de känner signalen och det gör de inte. Vet inte varför den inte känner igen signalen?
