Blästrade trösklar
Java
Re: Blästrade trösklar
Inlägg av Java »
Det finns färdigskurna kits för Modell3 också:
https://www.invisiblemask.com/
Tesla Joni
Inlägg av Tesla Joni »
Hi.
Yes i am the one who has been dealing with these issues now on global level. It started me after 1 weeks usage.
After 4 weeks it looked like this @ 2100 km.
Pls have a look on our group complaint:
https://nonono.com/case/tesla-group-com ... savolainen
My first video about issues:
4 k video @ 5441 km. White spots are missing paint.
I have 23 model 3 owners with me who has problems @ finland
At canada over 120 cases. Also i know problems from: portugal, norway, belgium, france, denmark and usa. Some of them are in rust already after 6 months usage.
Canada video:
I am in contact with canadians and i know the situation there.
Insideevs published @ united states my story.
https://insideevs.com/news/363399/tesla ... t-fragile/
https://insideevs.com/news/363703/more- ... -problems/
Need more info join our global facebook group of tesla paint issues:
https://www.facebook.com/groups/359891901375063/
Btw. Here is my toughts about this fuck up.
https://bbs.io-tech.fi/threads/tesla-mo ... st-5480673
Use translator that.
Br, joni
pefreli
Inlägg av pefreli »
Det verkar alltså handla om några hundra bilar worldwide som har problem med lacken.
Det har producerats över 300.000 Model 3 t.o.m. Q2-2019.
Det handlar alltså om runt 1-2 promille av bilarna som har detta problem.
Jag hoppas att ni som har problem med lacken får hjälp av Tesla. Men någon ”lack-gate” kan man knappast kalla det för. ;)
TM3 P svart/svart -24
TM3 P vit/vit -23, såld
TM3 LR AWD grå/vit -21, såld
14,6 kWp
Tesla Joni
Yet i can add these. This primer issues is another thing and it will affect a lot of Tesla Model 3:s. It just tells that the paint is thin!
https://www.bytbil.com/nyheter/larmet-r ... el-3-19711
http://elbilsnytt.se/tesla-3-agare-larm ... -och-rost/
https://www.expressen.se/motor/bilnyhet ... -och-rost/
My newest video tell you the news. Primer problem will have huge effect because those cars what are 84.000 € should not have these primer issues.
I have now inspected 4 cars and all those have primers issues. VIN: starts around 207.xxxx ends in 232.xxx so there are quite many cars.
Jeppe_E
Inlägg av Jeppe_E »
But most likely not all these cars has this issue. You cannot make the assumption that all VIN's between those numbers have issues. If there was 25000 cars out there with this issue, I am pretty sure that it would be a much much larger snowball. Again, I really hope that Tesla take their responsibility and fix this.
default
Inlägg av default »
Interesting that you have found a range in which the problem shows up. I'm in that range, 231xxx
Tesla Joni
Okey good to know. Do you have which color? Do you have primer showing around like in this video?
We know VIN starting with: 217363 is produced @ Tesla Fremont, California @ 21.1.2019.
We have verified this from Tesla service Centre. That car was delivered to customer @ Finland on 15.3.2019.
Melkin
Inlägg av Melkin »
For what it's worth, I have a blue LR AWD, 216xxx. No issues after nearly 7,000 km since the end of March. When I had it treated with OptiCoat Pro in May, I asked what they thought about the paint, since I had already seen complaints about it in this thread. They thought it was fine, not unusally thin or anything. I'm not saying this to provide an argument one way or the other on this topic in general, just sharing my personal experience.
2025 Tesla Model Y LR (Juniper)
2022 Tesla Model 3 LR
2019 Tesla Model 3 LR
Jeppe_E
Inlägg av Jeppe_E »
ippii
Inlägg av ippii »
I have a black LR with 214xxx VIN with exactly the same flaws as in your video. Also have ground paint shining through on the trunk, above the license plate.
default
Inlägg av default »
Just checked and I have a little bit of the problem with primer showing but not as bad as in the video. My worst parts are lower front part of front doors and around frunk and trunk hinges.
The worst for me is the softness of the paint. It seems however it is not quite as sensitive as when it was new, I think it has hardened a little.
Jeppe_E
Inlägg av Jeppe_E »
Vad har Tesla sagt om din bil då?
Tesla Joni
Same here. Have you checked the Finnish Chamber of commerce, Goods Inspector report ? Here it is. https://drive.google.com/file/u/1/d/1Ju ... gORpO/view
It says that paint is too soft and too thin even to touch it. :o I can't wash my car gently without leaving bad scratches.
Have you seen my latest video about primer issues? You should take it forward with your consumer protection officer & make tesla to paint your cars. We are going forward with our lawyers in here finland. :/
We have now 23 cases @ Finland. My vin is: 224547.
Here are some more photos: https://motor1.com/photos/693534/finnis ... -and-thin/ if you scroll them.
- Joni
default
Inlägg av default »
We have this thing called ARN but to my knowledge they only handle consumer disputes and my car is leased by a company. I almost got an appointment at the service center to get the damages checked, but now they have stopped answering emails again.
Tesla Joni
Same happening also in Finland. We contacted lawyers then they answered again.. :o
Max3
Inlägg av Max3 »
Hur mycket kostar det med stenskottsfilm på bara trösklarna inkl installation?
Någon som gjort det hos ditec?
tor-ake
Inlägg av tor-ake »
Vill passa på att tacka för tipsen om stänkskydd av olika sorter i den här tråden, även om det är 20 sidor bakåt dvs från sidan 1-15 ungefär. Fick mina från ebay idag och det var perfekt passform. Sjukt billiga jämfört med många andra alternativ, cirka 270kr med frakt. Även speciellt anpassade klips och skruvar ingick.
Det är den här modellen jag pratar om:
Och så här ser det ut när det är monterat på min vita bil:
Klistrade stenskottsfilm (biltema) på trösklarna enbart där stänkskydden ligger an. Kollade noga innan jag klistrade filmen och det var noll märken i lacken där efter 300 mil. Har ett stenskott mitt på motorhuven dock.
SALVETA
Inlägg av SALVETA »
Där jag kollat rörde det sig om 3-4000 för bodyfence skydd nere på trösklar och jag tror även det var tröskeln till bagaget som nog kan vara bra att skydda mot repor vid lastning.
Tänkte beställa stänkskydd först så man kan sätta på det samtidigt.
I övrigt hade jag tänkt vaxa bilen men det skulle man tydligen inte göra på filmen vilket var lite synd då jag trodde man även kunde skydda filmen lite och kanske få en mjukare övergång på kanterna på filmen.
Sent from my SM-G973F using Tapatalk
Walker
Inlägg av Walker »
Länk, tack.
eGolf (såld)
Model 3 LR (såld)
Ioniq 5 rwd (SÅLD!!)
Model Y LR -22 (såld)
Model Y LR -24
tor-ake
Inlägg av tor-ake »
Walker skrev:
Länk, tack.
Just den annonsen jag köpte från är inte aktiv längre men det var flera säljare som sålde exakt samma modell av stänkskydd till ungefär samma pris. Gå in på ebay.co.uk, sök på Model 3 mud flaps och kolla att det är samma bild som ovan.
Jag brukar klicka i filtret EU only så får man bara annonser från de som har ett litet lager och skickar från Europa vilket gör att man slipper postens momsfaktura och avgift.
Är du säker på det? Dom flesta folier går att behandla bara man vet vilken produkt som funkar, kan vara ett tips att kolla med Bollnäs Bilvård för dom är duktiga på just sånt, dom
la tex lackskydd på min förra bils folie och det var grönjävligt jäkla bra! :)
Dock FINNS det vissa folier som verkar kört att lägga på produkter på som funkar bra...
Däremot kanske det inte är precis ett vax utan en annan produkt som gäller...
SALVETA
Inlägg av SALVETA »
Däremot kanske det inte är precis ett vax utan en annan produkt gäller...
Nä jag är absolut inte säker och det tror jag inte han som sa det heller var även om han var erfaren och duktig, men det är väl lättare att avråda än att rekommendera att göra något som det kan finnas en risk med. Sen tror jag iofs att det finns mer lämpade produkter att använda på just filmen.
Det är bara jag som använt Meguiar's polish och vax på min tidigare bil och varit mycket nöjd med resultatet utan att ha testat något annat. Lacken är fortfarande fin på den 20 år gamla bilen trots det är några år sedan jag vaxade den sist.
Pratade även med en bekant som jobbar med rekond mm och frågade hur han skulle gjort om han precis köpt en ny dyr bil. Han sa att om det varit en "enfärgad" (hittar inte rätt ord) typ svart så hade han nog gjort någon typ keramisk behandling och med en metallic så hade han nog vaxat den. Han använde även själv Meguiar's då och då, så där fick jag åtminstone lite bekräftelse på att jag gjort ett hyfsat val för många år sedan när jag började med deras produkter.
Annars är det lite snack om vax här, är det för att andra produkter faktiskt är bättre eller för att dom är nyare, häftigare och syns i reklam från olika firmor som vill sälja sin egen superprodukt/teknik som är svårare att göra själv?
default
Inlägg av default »
Var äntligen inne på SC för besiktning av bilen. Tyvärr var personen som hanterar denna typ av ärenden på semester, trots avtalad tid, men jag fick i alla fall visa upp bilen. En ung trevlig kille tog ett par bilder så det hela tog fem minuter. Tråkigt att behöva åka till Göteborg och ta en övernattning för det, speciellt eftersom jag redan skickat bilder, men men.
Killen frågade, och det har tidigare frågats via mail också, om det kunde vara en transportskada men självklart är det inte det. Jag får känslan att de har order att laga transportskador men vara väldigt restriktiva med andra reparationer. Vidare påstod han att de inte fått in någon bil som sett ut som min innan. Han sa även att de hade haft bilar inne för stenskottskador och inga av dom hade åtgärdats, det var policy. Känslan var att han höll med om att det inte är normalt som det ser ut på min bil men vi får se. Jag skulle få någon form av återkoppling i veckan som kommer.
TeslaM3
Inlägg av TeslaM3 »
Ni som installerat stänkskydd har ni skruvat fast dem i de två hålen nedtill som har ”pluppar” på sig? Hur gör ni med det som sitter upptill på stänkskyddet? Har bara två hål nedtill på bilen.
Nico
Inlägg av Nico »
Fick med längre klipps när jag köpte stänkskydden. Upptill satte jag en rostfri skruv.
Model 3 Long Range AWD
