4000 mila service - vad gör dom?
josve
Inlägg av josve »
Vet att det tidvis diskuteras om man behöver serva en Tesla, lite praktisk erfarenhet;
Nedan är vad man gjorde vid min 4000 mila service (tidigare servat den vid 2000 mil).
Förutom ordinarie service genomgång bytte man delar av bromsarna (utan kostnad)
Corrections: Upgraded brakes to 2nd generation cold weather spec due to degraded brake performance. Replaced brake rotors
because uneven wear caused by seized brake pads.
Man bytte även en länkarm som hade påverkats av att man använt en för lång bult vid infästning som på något sätt
påverkat funktionen. (utan kostnad)
Corrections: Replace LH and RH Lower Shock Absorber Bolts; Replace LH Fore Link.
Replaced left fore link and front lower shock absorber bolts.
I den ordinarie servicen har man gjort följande;
Corrections: 24 Month/25000 Mile/40000 km Service (with Coil Suspension)
Pulled logs and checked for active faults: No active faults (11/9/15).
Checked firmware version: Updated to latest version 6.2 (2.5.46U).
Performed function check of closures (moving glass, doors, trunks): Cleaned and lubricated latches. Good, no issue.
Tested and inspected customers charge cable: Good, no issue. Vehicle charged normally @16A.
Replaced:
A/C Desicant bag
Brake fluid
Wiper Blades
Key Fob Battery
Cabin Air Filter
Remote Keyless Entry: Good, no issue
Seat belts and latches: Good, no issue
Interior/exterior lighting and horn: Good, no issue
Performed inspection of powertrain and chassis components: Good, no issues.
Checked fluid levels: Topped off washer fluid. Brake and coolant levels optimal. No signs of leakage.
Inspected tires and rotated as wheels (below mensioned positions are now switched front/rear).
Measured tire tread depth at:
(Outer) (Center) (Inner)
LF: 7 7 7
RF: 7 7 7
LR: 6 6 5
RR: 6 6 5
Adjusted tire pressures to B-pillar spec: 45psi Front, 45psi Rear
Measured brake pad thickness (mm)
LF: RF: LR: RR: Park:
10 10 10 10 4
Performed 4-wheel alignment check: Good
hybris
Re: 4000 mila service - vad gör dom?
Inlägg av hybris »
Skriver kontrakt? ;-)
Martinen
Inlägg av Martinen »
Fick inget svar på min fråga i andra tråden. Vägrar Dom göra service om man inte skriver på?
hybris
Inlägg av hybris »
De vägrade inte byta mina däck pgr av folieringen i varje fall. Kanske kan teknikern snubbla och bryts nacken pgr av den oerhörda skönheten? ;-)
Om du har tredjepartsfälgar och de skall göra något som påverkas? Ingen aning...
