Samsung unveils solid-state lithium metal batteries
Samsung surrar om solid state batterier.
Skulle kunna ge en BMW i3 en räckvidd på 660km.
Samsung unveils solid-state lithium metal batteries.
Highlights:
Cycle life: 95 % SoH after 600 cycles and 89 % SoH after 1.000 cyclesVolumetric energy density: 942 Wh/L with potential to surpass 1.000 Wh/L
SoH (State of Health) is used to measure battery capacity retention.
With this kind of volumetric energy density the BMW i3, which currently uses NCM 622 battery cells from Samsung SDI, could get a 89,9 kWh battery and an approximate WLTP range of 660 km. It would still have a range of 627 km after 386.100 km [(660 + 627) / 2 x 600] and 587 km after 623.700 km [(660 + 587,4) / 2 x 1.000].
https://pushevs.com/2020/03/10/samsung- ... batteries/
[JM]
Re: Samsung unveils solid-state lithium metal batteries
Inlägg av [JM] »
Om man ska tro det här:
https://www.maximintegrated.com/en/desi ... ology.html
Instead of the smaller 18650 cells used in Model S and Model X, the new 21700 Li-ion cell is used in the Model 3. The 21700 (Figure 1) has a diameter of 21mm and length of 70mm (this type number says nothing about performance or chemistry, by the way). Tesla calls it their 21-70 battery. The 21-70 cell volume is 24.245mm³. That’s 46% more than the 18650 cells. They are also about 15% more 'energy efficient,' according to a statement by J. B. Straubel, Tesla’s chief technology officer. Energy density is thought to be 877.5Wh/L and cell capacity is 21.275Wh.
Så är ju Tesla redan där med ca 877.5Wh/L i 21700 Cellerna.
Men det kanske är Cykel/Livslängd och Strömtålighet som man i första hand siktar på att SolidState-batterierna ska hjälpa till att lösa?!
GM surrar ju också om "double the energy density."
During their EV Day, General Motors actually let guests have glimpses of just that.
Although GM did not mention it in the press release, Navigant Research engineer and Forbes contributor Sam Abuelsamid wrote “We were also shown a lithium metal test cell that should eventually double the energy density.”
Sen är det ju lite märkligt att Samsung inte säger nåt om temperatur tålighet. Mycket vore ju vunnet om man slipper värma/kyla batteriet.
Om batteriet exempelvis klarar 300 C utan att skadas, då finns ju möjligheten till rejält högre laddhastigheter.
Mera info om Samsung batteriet.
