Citroen e-SpaceTourer
Citroen e-SpaceTourer: specs and details of nine-seat electric minibus.
Sister model to Peugeot e-Traveller revealed; five to nine seats available.
Like the equivalent Peugeot model, the Citroen e-SpaceTourer has a 50kWh battery, giving a driving range between charges of 143 miles. The battery is located under the floor and so doesn't impinge on passenger or luggage space; it's covered by an eight-year/100,000-mile warranty.
Charging is possible from a conventional three-pin socket, a home wallbox (7.4kW), a workplace wallbox (11kW) or a public rapid charger (up to 100kW). From the latter, an 80% top-up will take half an hour, rising to nearly five hours from the 11kW wallbox and seven-and-a-half hours from the 7.4kW wallbox.
https://www.drivingelectric.com/citroen ... ic-minibus
PoloPrinsen
Re: Citroen e-SpaceTourer
Inlägg av PoloPrinsen »
Bra att det är på gång andra elbilsalternativ än de vanliga.
Mvh PP.
Reserverat en Sion från Sonomotors. Har den nya, aktuella referral-koden som gäller april ut i år! Om du vill spara 125Euro så säg till! (får ej ange koden här i signaturen).
