Parking for 60 days
swapnilpt005
Parking for 60 days
Inlägg av swapnilpt005 »
Hello Members,
I need to park my Tesla Model 3 LR for 60 days as I am traveling out of Sweden.
I will park my vehicle at rented parking places (Indoor) but don't have the possibility to plug in a charger while I Park.
I need your suggestions for
  • To what % I should charge before parking?
    How much battery % I can expect to remain after 60 days considering the sentry mode On/Off?
    How frequently I can check the remaining battery % using Tesla app in order not to awaken the car and costume extra battery?
    Any other precautions I should take before parking?
    Any good suggestions for indoor parking garages in Solna?
    Will there be a big impact on battery drain if I don't manage to get an Indoor parking place and need to park my Car out in winters?
Thanks,
Swapnil
Trevlig
Re: Parking for 60 days
Inlägg av Trevlig »
Park it with 80%
DON'T CHECK the app.
sentry mode OFF
Bilar: Tesla model 3 LR 2023
tor-ake
Inlägg av tor-ake »
I'd charge as high as possible without causing excessive degradation, maybe 90%. Then disable sentry mode, and double check that it's actually disabled. Log out of the app to ensure that the phone does not do any funky business on its own. Disable and log out of any extra services such as ABRP or TeslaFI. Check the battery by logging in to the app maybe once after 30 days, then log out again.
Finally, talk to a friend on beforehand, and agree on action plan if the battery becomes critical for one reason or another. You can remote start the car and your friend can do a rescue mission, take it to a charger. Shouldn't be necessary, but better that, than having to wait for Roadside Assistance with a bricked car on your return.
Trevlig
Inlägg av Trevlig »
Maybe some fellow Tesla owner can take care of your car? :D
3 veckor i denna video:
ca 10% tappade han på den tiden, parkerad utomhus vintertid. Startade med 77%
Checking the app once a week do not consume much.
My model 3 goes to sleep within 5 minutes after closing app, sometimes it takes a little longer, probably because 12 volt battery needs a little charge.
(Sentry mode off)
80% charge when parking should be fine. Report back when you return!
pefreli
Inlägg av pefreli »
If you use TeslaFi or similar, make sure you have the right settings so the car stays asleep…
TM3 P svart/svart -24
TM3 P vit/vit -23, såld
TM3 LR AWD grå/vit -21, såld
14,6 kWp
swapnilpt005
I parked my car for 2 months and lost 65 kms in range. I didn't check the app when the car was parked.
