https://europe.autonews.com/automakers/ ... tery-powerCitroen will add a full-electric version of the C4 Cactus successor when the compact hatchback is renewed next year, CEO Linda Jackson said.
The battery-powered variant of the C4 Cactus replacement will be Citroen's first mass-market EV.
The C4 Cactus replacement will be a "very important launch for us," Jackson said.
Citroën ë-C4
Citroën ë-C4
Re: Citroen C4 Cactus BEV
Nu lanseras Citroen ë-C4 den 30 juni.
EDIT:
Tyvärr tycker jag att man inte lyckats så bra med utseendet med nya Citroen C4.
https://www.motor1.com/news/429119/2021 ... -revealed/
https://www.electrive.com/2020/06/16/fi ... roen-e-c4/
Citroën has published first pictures of the new C4 and its purely electric offshoot ë-C4. The new C4 shares only the name with its predecessors, the French have said goodbye to the classic compact car. Information about the technology of the ë-C4 is not yet available.
The official world premiere of the new Citroën C4 and ë-C4 will take place on June 30th, in about two weeks there will be more details about the model. However, in view of the other plug-in hybrids and electric cars from the PSA Group, it is unlikely to come as a surprise; PSA currently uses its drives in as many different models as possible. For the BEV, this is would be the 100 kW drive, which in passenger car models is combined with a 50 kWh battery.
Citroën speaks in the communication of a “comeback in the compact sedan segment”, but the pictures now published show that the C4 is not a Golf-style compact car, but rather a five-door SUV coupe. The body is raised in the typical SUV style, with dark plastic applications all around for a robust look. “The elegance and dynamism of a sedan are cleverly combined with the powerful character of an SUV,” says the communication.
EDIT:
Ev database tror på ett pris på 40.000 euro för Citroen C4.
https://ev-database.org/compare/newest- ... g:number=9
https://pushevs.com/2020/06/30/citroen- ... tric-e-c4/
Citroën unveils the all-electric ë-C4
Citroën ë-C4
Post Author:Pedro LimaPost published:30/06/2020Post Comments:0 Comments
The PSA Group launches another electric car built on the new e-CMP platform, the Citroën ë-C4.
Let’s some parts of the press release.
ë-Comfort means being able to drive 100% electric, with:
– Zero CO2 emissions to satisfy customers’ environmental and ecological conscience
– Zero noise and zero odour, to ensure optimum comfort in terms of noise and odour in electric mode in town
– Zero vibrations, zero jolts, zero gear changes, for perfectly smooth driving
– Immediately available torque for stimulating driving sensations
– Remotely programmable services for peace of mind every day
– Reduced maintenance costs
> SMOOTH 100% ELECTRIC DRIVING
New ë-C4 – 100% ëlectric has an efficient engine with zero CO2 emissions and a WLTP cycle range of 350 kmi. In addition to the pleasure of driving 100% electric, with no CO2 emissions and real savings in use, New ë-C4 – 100% ëlectric allows access to the restricted traffic areas of cities, which are increasingly off-limits to conventional engine vehicles.
This 100% electric engine is particularly powerful and energetic, whatever the circumstances, with 136 hp of power, 260 Nm of torque instantly available for clean, linear acceleration, 0-100 km/h in 9.7 seconds in Sport mode and a top speed of 150 km/h. The 50 kWh electric motor battery is high-voltage 400 V Li-Ion.
New ë-C4 – 100% ëlectric has a Brake feature that amplifies deceleration of the vehicle without pressing the brake pedal, to increase range. This system allows recovery of the energy available during braking and deceleration phases, unlike the conventional ICE versions. This action lets the driver partially recharge the battery and increase range.
Several driving modes are available, activated by the mode selector on the centre console: Eco, Normal or Sport, which acts on various parameters including air conditioning and effective power and performance, allowing the driver to choose between dynamism or optimal eco-driving.
For even greater peace of mind, the battery is guaranteed for 8 years or 160,000 km for 70% of its charge capacity.
> OPTIMISED CHARGING TIME FOR EASY RECHARGING
Charge time is optimised:
– In mode 4 on a public charging station, using a 100 kW fast-charge charger, the battery recharges at a rate of 10 km/min, a value at the best level in the segment: 80% of the charge is completed in 30 min.
– In mode 3 at home, on a 32 A Wall Box either purchased or rented, battery recharging is accelerated and takes 7.5 hours in single-phase, or even 5 hours in three-phase with the optional 11 kW charger.
– In mode 2 at home, for occasional needs, the battery can be recharged in 15 hours on a 16 A Legrand Green’up™ type socket and more than 24 hours on a standard domestic socket.
To make life easier for customers and enable them to enjoy their electric vehicle with faster charging times on a daily basis, Citroën takes care of everything and offers a “one-stop shop” solution for installing a Wall Box at home.
Charging is simplified and can be programmed or deferred, to benefit from more advantageous off-peak electricity prices for example. Customers program the vehicle charge using the tablet in the passenger compartment or using the My Citroën app. Charging is simple thanks to improved ergonomics of the flap and the charging cables stored on the hinged boot floor. The charging flap features a colour code to visually track the charging process, which can also be viewed on the My Citroën app.
Citroën ë-C4 interior with HUD (Heads-up Display)
Dimensions
Length: 4.360 mm
Width: 1.800 mm / 2.032 mm mirrors extended / 1.834 mm mirrors folded
Height: 1.525 mm
Wheelbase: 2.670 mm
Wheel diameter: 690 mm
Turning circle: 10,9 m
Ground clearance: 156 mm
Boot volume: 380 l, up to 1.250 l
Loading sill height: 715 mm
Powertrain
Power: 100 kW (136 HP)Torque: 260 Nm
Maximum speed: 150 km/h (93 mph)
0-100 km/h: 9,7 seconds (sport mode)
Battery capacity: 50 kWh (46 kWh usable) in 108s2p configuration (216 cells from CATL)
Range: 350 km (217 miles) in WLTP cycle
Battery warranty: 8 years or 160.000 km for 70 % of its charge capacity
Charging
100 kW public charging station: battery recharged to 80 % in 30 min, i.e. 10 km/min
32 A Wall Box: between 5 hours (three-phase with the optional 11 kW charger) and 7 hours 30 min (single-phase)
Domestic socket: between 15 hours (high-power socket) and more than 24 hours (standard socket)
Citroen C4 EV kommer i november.
https://m.bilnorge.no/artikkel.php?aid=52739
Citroen e-C4 – first look and walkaround of new Citroen electric car – DrivingElectric
Re: Citroen C4 EV
Om vi bortser från att det rör sig om en SUV, som kommer ge sämre räckvidd jämfört med en vanlig personbilskaross pga högre vikt och sämre luftmotstånd – bilen har högre markfrigång och är högre och bredare än en vanlig personbilskaross… (Jag skulle personligen inte kunna bortse från det, men det gäller ju uppenbarligen inte alla*...)
Jag förstår ju inte alls hur de tänkte när de designade bakpartiet på den bilen. Och fronten är ju inte direkt någon jättehit den heller…
Den kommer tydligen att kunna fås med HUD, men i sammanhanget tycker jag det väger väldigt, väldigt lätt…
________________________________________________________________________________________
*Jag vet att det ju tyvärr inte finns ett enda alternativ till SUV ifall man vill ha en elbil med kombikaross, och att det även finns dåligt med halvkombikarossalternativ...
StefL
Jaha, dom fick gå runt bilen men inte ens röra vid den, än mindre öppna dörrarna, provsitta eller - gud förbjude - provköra. Sånt här ser jag som rent Clicbait vars innehåll lika gärna kunde gjorts tillgängligt med en tre raders faktaruta och en bild...Zalman3 skrev:Citroen e-C4 – first look and walkaround of new Citroen electric car – DrivingElectric
Re: Citroën ë-C4
https://www.electrive.net/2020/09/16/ci ... -766-euro/Efter att beställningarna för Citroën ë-C4 startade i Frankrike för några dagar sedan, kan Stromer nu också beställas i Tyskland.
Listpriserna i detta land börjar på 33 766 euro (inkl. 16% moms). Citroën lovar de första leveranserna i december 2020.
Så snart ë-C4 ingår i BAFA-listan, med avdrag för den ökade miljöpremien, kan den bli 24 286 euro.
Om mervärdesskattesatsen stiger till 19 procent igen vid årsskiftet kommer bruttopriset på ë-C4 i Tyskland att vara 34 638 euro - efter avdrag för miljöbonusen kvarstår 25 068 euro.
