17" på M3LR
Här diskuterar vi hur man lagar och modifierar sin Tesla.
Klafver94
17" på M3LR
Inlägg av Klafver94 »
Tjenare! någon som hittat en 17"-fälg som passar på en M3LR? :D
Hata Skellefteå :*
Re: 17" på M3LR
Det verkar inte som det är en särskilt bra idé...
Från det (utmärkta) amerikanska forumet Tesla Motors Club:
Downsize-for-winter - Welllll, it's almost exactly what I thought from the photos we've seen... you CAN fit a 17", but it's razor-thin close over the rear brakes. And when I say "a" wheel, I mean "a" wheel. Out of the 85 models we have in the right 17" specs. there is exactly one that fits over the rear brakes, and that with just 2.1mm of clearance to the barrel. On paper that is the absolute bare minimum we would ever consider for acceptable caliper-to-inner-barrel clearance, but until we can do some real-world testing we're not going to allow it as it's pretty clear the car wasn't designed for 17".
Source: https://teslamotorsclub.com/tmc/posts/2497188/
Klafver94
Re: 17" på M3LR
Det var synd! Siktade på ett minimum av 4mm i frigång. Lite lustigt att bromsarna bak är större än fram på M3
Hata Skellefteå :*
