https://www.autoevolution.com/news/tesl ... 69429.htmlTesla Hacker Says Replacing Battery Pack Modules in Model S Doesn’t Work.
Tesla always chooses the easiest path for repair in its cars despite the cost for its customers.
That said, it will give them a $16,000 estimate for a repair that could cost $700, as we have already told you.
It also provided a customer with a $22,500 estimate (without taxes) for something that the Electrified Garage fixed for $5,750.
However, Jason Hughes, also known as Tesla Hacker, said the automaker's procedure was correct in this case.
Replacing battery modules would be just a temporary fix: imbalances would make the Model S present the same issue in the future.
Svårt att bara byta batterimodul på MS
Att bara byta en batterimodul har visats sig svårt. Bäst är att byta hela batteriet.
TobbeTesla
Det man ju tydligen kan göra är att "klippa" och koppla förbi kopplingarna till de dåliga cellerna, batteriet får således en något lägre kapacitet men blir "friskt". Kolla youtube så förstår ni hur jag menar.
