That's why we have come up with this list to find the best vacuum for long hair and make your cleaning jobs a lot easier. Let's review them below!
What Is The Best Vacuum For Hair?
To get rid of human hair and pet hair in your house, you will need a vacuum with immense suction power. While there are many different models with various functions, you should purchase machines that won't allow tangled hair or hair clogs that might affect the airflow.
Types of Vacuums
Before we get to the list of the best vacuum for long human hair, here are some of the most popular vacuum types to consider.
1. Upright Vacuums
Upright vacuums are the most effective at removing human and pet hair. However, these models are heavy and corded, which is hard to carry around the house or clean above-floor areas.
Some users love upright vacuums for their suction, but some people find them difficult to maneuver and use. These models are best at removing dirt and hair from the floor, but the big size and power cord limit their flexibility.
2. Stick Vacuums
Stick vacuums, on the other hand, are most popular for long hair. These stick vacuums are lightweight and compact, making them easier to lift and carry around the house.
We all know that hair tends to fall everywhere, and stick vacuums can help you remove hair from your furniture, window sills, and shelves. In addition, the ultra-lightweight stick models often come with modern technologies for picking up long hair, such as self-cleaning brush rolls, tangle-free rollers, and various pet tools.
Robot vacuums can pick up a sufficient amount of hair. However, they are not as reliable as the traditional upright vacuums or modern stick vacuums. Therefore, some robot vacuums include tangle-free hair technology to pick up more hair from the floor.
Overall, it depends on your specific cleaning needs when you decide on a vacuum cleaner. Here are our picks for the best vacuum for human hair.
Best Vacuum For Hair In 2021
1. Best Upright: Shark Vertex DuoClean PowerFins Upright Vacuum
The Shark Vertex is one of Shark's latest and most improved upright series. This vacuum has exceptional suction power for picking up pet and human hair on the floor. Additionally, the DuoClean PowerFins technology includes a soft roller and a PowerFins roller to deep dive into the carpets and pick up every strand of hair on its path.
Pros:
Powered Lift-Away lets you use the Shark Vertex both as an upright vacuum and a handheld vacuum.
Different suction levels for cleaning on multiple surfaces.
Duoclean PowerFins technology for the best deep cleaning results.
Strongest suction and airflow in Shark upright series.
Exceptional at picking up long human hair and pet hair.
Cons:
The soft roller requires regular cleaning.
2. Best Stick: Dyson V11 Torque Drive
If you love an intelligent cordless vacuum, the Dyson V11 is the best option for your home. According to Dyson, this vacuum is lightweight but has twice the suction of other cordless vacuums. In addition, since the V11 is cordless, you can easily vacuum anywhere in the house without worrying about the portability limitations of the power cord.
The Dyson V11 is 20 percent more powerful than its previous model, the V10. It weighs less than 7 pounds, which is ideal for carrying from room to room. We love the LCD displays that show remaining run time, selected power mode, and maintenance issues. This vacuum is best for small to medium homes with pet and human hair.
Pros:
Excellent suction power
Lightweight and versatile
Extended run time (up to 60 minutes on Eco Mode)
Intelligent LCD displays
Three cleaning modes: Eco, Auto, and Boost mode.
Cons:
Quite expensive
3. Best Robot: iLife V3s Pro Robot Vacuum
The iLife V3s is the best robot vacuum for long hair at an affordable price. This self-operating machine can pick up hair from tight corners, under low furniture, and other hard-to-reach areas.
Different from other robovacs with brush rolls, this particular model includes a 3-inch suction opening to pick up the hair and send it straight to the dirt compartment. As a result, you won't have to worry about using scissors to cut the tangled hair from the roller.
In addition, the iLife V3s comes with smart sensors to help them navigate around the room without bumping into objects and walls.
Read More: Best Vacuum for Long Hair: Great Models to Purchase
Pros:
Impressive hair cleaning performance
Affordable
It can clean under your sofa, beds, and other tight corners with ease
This vacuum is self-charging and self-operating
Great at navigating around the room without scratching the furniture
Cons:
It takes time to clean the entire house
Frequently Asked Questions: Best vacuum for hair removal
1. Question: What is a HEPA filtration system?
HEPA is short for high-efficiency particulate arrestance. This type of filter helps prevent air from escaping outside the machine, which traps 99% of dirt, debris, hair dander, and other particles in the main unit.
If you suffer from allergies or other respiratory conditions, it's best to get a good vacuum for hair with HEPA filters to keep the air in your house clean.
2. Question: How do I vacuum the carpet by cleaning with baking soda - baking soda for cleaning ?
If your carpet starts to smell, you can try cleaning it with baking soda to return it to get rid of the unpleasant odor. Baking soda is anti-microbial and great at tackling pet stains. What you need is a box of baking soda, your vacuum cleaner, and a broom.
First, you should remove all the furniture and obstacles for better access. Then, give your carpet a quick clean with your vacuum cleaner before you sprinkle baking soda across the stained areas.
Next, you can use a broom to spread the powder evenly on the carpet. It would help if you let the baking soda sit for at least half an hour, or you can give it an overnight rest for a more serious odor problem. Finally, run the vacuum across the area a few times to remove the baking powder.
3. Question: What is the best vacuum for hair on carpet?
Shark APEX Uplight Vacuum with DuoClean comes with an extremely powerful brush roll that can tackle all hair on your carpets. This model also includes a HEPA filter and DuoClean brush roll to dig deep into your carpet and remove long hair with no problem.
Conclusion
Thank you for reading our best vacuum to pick up hair review. We know that finding the right vacuum for your home can be difficult, and we hope this article helps you make the best purchasing choice.
