Tydligen har airbagstillverkaren Takata gjort ett misstag vid utvecklingen av sina airbags som gör att under vissa specifika förhållanden funkar de inte som de ska. Egentligen påverkar detta endast Model S byggda under 2012 men för att vara på säkra sidan så kommer Tesla efterhand byta ut airbags i alla Model S som byggdes fram till och med 2016.
Från NHTSA
A combination of time, environmental moisture and fluctuating high temperatures contribute to the degradation of the ammonium nitrate propellant in the inflators. Such degradation can cause the propellant to burn too quickly, rupturing the inflator module and sending shrapnel through the air bag and into the vehicle occupants.
The science clearly shows that these inflators become unsafe over time, faster when exposed to humidity and variations of temperature.
Från Tesla
Tesla will replace the passenger airbags in all 2012 Model S vehicles globally. The safety of our customers is paramount and Tesla is taking this action even though there have been no airbag ruptures or other related incidents in any of its vehicles.
Although the current recall only applies to 2012 Model S vehicles, the passenger airbags of all Model S vehicles produced through late 2016 are expected to eventually be recalled. If you own a Model S produced between 2013 and 2016, your airbags are safe, and you do not need to take any action until you receive further notice from Tesla. As noted by NHTSA, customers do not need to be concerned about Takata inflators before they receive a recall notice. Nevertheless, for convenience and peace of mind, Tesla will make every effort to proactively replace the airbags of all affected vehicles even before they are recalled. This will be performed as parts supply allows, and at this time you do not need to take any action.
Ja, det var ju en tidsfråga innan återkallningen skulle komma, då det cirkulerat uppgifter att Tesla också har dessa krockkuddar. Men som sagt, problemet uppstår när krockkuddarna åldras, så ingen omedelbar fara.
Den obligatoriska återkallningen gäller 2012. Det är väl de som är så gamla att de måste bytas. Takata verka ha använts till 2016. Tesla kommer att byta dessa också. Jag gissar att dessa skulle återkallas längre fram om den inte byts. Därför byter Tesla dem också redan nu innan det blir obligatoriskt.
Fick nyss mail om det här från Tesla iaf, gäller som sagts väldigt få bilar, typ tidiga 2012:or samt andra hälften av 2016 (?)...
Har de gjort ytterligare ett översättningsfel?
Enligt ovanstående artikel är det samtliga bilar producerade fram till slutet av 2016 vilket betyder även bilar från 2013, 2014 och 2015
Ja det var ett dåligt översatt meddelande.
Trots att denna återkallelse endast berör Model S tillverkade under 2012, kommer även sensorn i passagerarkrockkudden i alla Model S som tillverkades under andra halvan av 2016 att återkallas i framtiden. Om du äger en Model S som var tillverkad mellan 2013 och 2016 finns det ingen risk för defekt utan passagerarkrockkudden är säker och inga andra handlingar krävs från dig förrän Tesla tar kontakt med dig.
Originaltexten säger "all Model S vehicles produced through late 2016". Fascinerande att en professionell översättare inte vet betydelsen av 'through' i det sammanhanget.
Jag skulle vara fascinerad om de faktiskt använde en professionell översättare.
Så länge du har betalt för att göra ngt gör du det professionellt!
Kanske någon ägare bör kontakta Tesla och se till så att de skickar ut rätt information till ägarna?
Ni kanske även ska tipsa de att använda Google translate i fortsättningen?
Det är nog rätt information. Dom skyndar på i USA för att inte få stämningar på sig. Vi i europa är inte så viktiga.
I live in Europe/Asia. Is my Model S part of the recall?
While your vehicle is not a part of the Takata recall, Tesla will replace the passenger airbags in Model S vehicles globally on the same schedule that it replaces passenger airbags in Model S vehicles in the U.S., starting with 2012 vehicles. The safety of our customers is paramount and Tesla is taking this action even though there have been no airbag ruptures or other related incidents in any of its vehicles.
Det betyder inte att du är proffs på det du gör.
Nej, men man brukar ändå kunna förvänta sig någon lägstanivå av någon som ska kunna försörja sig på något. Men visst, det kan hända att de helt enkelt låter folk i den egna organisationen översätta saker.
av tidigare översättningar att döma så känns det som en amerikan som varit två veckor på språkresa i Sverige och tycker sig kunna svenska (har säkert en svensk i släkten femtielva generationer tillbaks också, så då är personen i stort sett svensk enligt amerikanskt sätt att se på det) har fått uppdraget.
Men de skriver att bilar sålda andra halvan av 2016 ska återkallas men inte bilar sålda under 2015. Visst är de under 2012 kanske viktigast men de är ju ändå de i slutet av 2016 som inte är berörda trots att de låter så i mailet.
Var skriver de att bilar sålda under 2015 inte ska återkallas, förutom i den galna svenska översättningen?
Det är just det jag menar, svenska teslaägare som inte hänger här kommer tro att deras bilar som är producerade 2015 inte är drabbade av återkallelsen. Visst, antagligen är det inget fel på de men om de ska återkallas kanske de har rätt att veta det?
I FAQ'n som jag citerade. Dom gör skillnad på amerikanska och europeiska/asiatiska bilar.
Nu kanske jag har förlagt min läskunnighet såhär på eftermiddagen, men det står inget alls om det i den texten som du klippt in...? Det står tvärtom att de kommer att byta ut airbags globalt enligt samma schema som de kommer göra i USA, vilket vi redan konstaterat kommer börja med årsmodell 2012 och senare sträcka sig hela vägen till bilar producerade sent 2016.
Amerikanska bilar återkallas.
Våra bilar återkallas inte. Dvs, du behöver inte åka in med bilen enbart för detta nu direkt. Någon gång framöver när bilen passerar ett service center så kommer dom kanske att bytas.
Så tolkar jag det inte. Jag tolkar det som att bara amerikanska bilar berörs av Takatas återkallelse. Takata har åkt dit stenhårt i amerikanska domstolar och tvingas göra enorma återkallelser i USA, men har inte tvingats till detsamma av EU. Men Tesla kommer frivilligt, på samma schema som de skriver, att göra samma åtgärder på europeiska bilar. Flera andra tillverkare har gjort samma sak, exempelvis Toyota.
