Volvo ES90
Volvo ES90
Volvo Cars is working on an electric version of its luxury saloon, which will launch in 2025 as the ES90. According to media reports, the carmaker has already built the first prototypes at its plant in Shanghai. Deliveries will kick off in mid-2025.
According to information from motor.es, the Volvo ES90 will be based on the SPA2 platform and come with one or two electric motors. The battery will be rated at 111 kWh gross or 107 kWh net, allowing for a range of more than 600 kilometres.
The electric version will be slightly larger than its ICE counterpart. It will measure 4,999 mm in length, while the S90 is 4,963 mm long. The EV will be 1,945 mm wide and 1,547 mm high and have a wheelbase of 3,102 mm. The S90 measures 1,879 mm in width and 1,443 mm in height. Its wheelbase is 2,941 mm.
The all-wheel drive version of the ES90 tips the scales at 2600 kilograms. And the single-engine variant is said to weigh 2.5 tonnes.
According to motor.es, the new electric Volvo will go into production as early as May 2024. The carmaker will then hand over the first units to customers in mid-2025.
Verkar bli en riktig bjässe. Inte så länge till maj heller.
https://www.electrive.com/2023/12/21/vo ... n-in-2025/
Pasjostrom
Re: Volvo ES90
Inlägg av Pasjostrom »
Herregud Volvo, bättre än så kan ni, ingen vanlig personbil ska behöva väga 2,6 ton, speciellt inte en sedan.
Re: Volvo ES90
Pasjostrom skrev: 21 dec 2023 17:39
Behöver man 111 kWh batteri för att uppnå tillräcklig räckvidd så drar det snabbt iväg i vikt.
EX90 väger väl närmare 3 ton?
Model Y P
Model S P
Model S P
Pasjostrom
Re: Volvo ES90
Nicke Nyfiken skrev: 21 dec 2023 17:45
Jag vet, men en av anledningarna till att bilen behöver så stort batteri är att den är så tung, så det blir en ond cirkel.
Vet att EX90 också är extremt tung, vilket jag också ogillar…
Re: Volvo ES90
Pasjostrom skrev: 21 dec 2023 18:29
Extremt och extremt. Det är väl 200kg mer än en model S?
Re: Volvo ES90
Fredrik j skrev: 21 dec 2023 18:49
En S Palladium väger 2200 kg.
En S Raven väger 2240 kg.
Model Y P
Model S P
Model S P
