MG lanserar en elkombi, MG5, pris ca 29.000euro.
MG utökar sitt sortiment med elkombin MG5.
Kommer Q4 2020 i England.
Förväntat pris £25,495/€29,000.
MG Soon To Introduce All-Electric Estate Called The MG 5 In The UK.
MG surprised with another all-electric model for the UK (possibly also in other European markets).
MG (part of Chinese SAIC) is expected to introduce its second all-electric model in the UK this year, and start sales "as soon as showrooms reopen."
This new model turns out to be an electric estate MG 5, which is expected to be an upgraded and rebadged SAIC Roewe Ei5, available in China since 2018.
There are no details about the MG 5, so we don't know whether the specs will be the same as the Ei5, which is equipped with a 52.5 kWh battery for 420 km (261 miles) of NEDC range, and 85 kW electric motor.
One thing is sure, the MG 5 is poised to be the first all-electric estate in Europe, as the customer deliveries will begin in Q4.
This way, SAIC is expanding its plug-in portfolio in Europe. The MG ZS EV already is available in multiple European countries and seems to cope relatively well.
If the MG 5 is affordable (Autocar expects £25,495/€29,000 after Plug-In Car Grant compared to 130,800 yuan/£15,000 for the Ei5 in China), maybe more people in Europe will consider Chinese EV.
Besides the MG ZS EV and MG 5, MG intends to launch in 2020 also a plug-in hybrid SUV, the MG eHS model.
SAIC Roewe Ei5 specs:
52.5 kWh battery
0-50 km/h (31 mph) in 4.8 seconds
top speed of 150 km/h (93 mph)
85 kW and 255 electric motor
AC normal charging in 8.5 h
DC fast charging by 80% in 40 minutes
https://insideevs.com/news/414209/uk-mg ... ic-estate/
Roewe Ei5 Fully Electric Car
Längd 4544mm
Bagage 479/1367 liter
http://www.chinamobil.ru/eng/roewe/ei5/?view=props
Re: MG lanserar en elkombi, MG5, pris ca 29.000euro.
Första kombin "här"... hrm...
tobiaslej
Inlägg av tobiaslej »
vilken prispress redan. kina ser väl sin chans att bli dominerande inom fordonsindustrin (om / när) elbilarna tar över.
Model 3 SR+
Model Y Performance
Och ändå är den dyr i Europa.
Den kostar mellan 18.160-22.390 dollar i Kina.
Roewe?är inte det gamla Rover som också blev köpt av kineser?
0-50 på 4,8 :lol: ja, det är ju också ett sätt att ange acc. Trodde först det var till 100 och var benägen att bli impad!
Model 3-24/Polestar 3-24
Det pratas om att MG 5 får 750kr dragvikt, 3kW V2X eluttag, 11-22kW 3-fas laddning.
specifikationer:
Effekt: 85 kW / 116 hk
Elektriskt område (min / genomsnitt / NEDC / WLTP * förväntat): 280 km / 320 km / 420 km / 330 km
Batterihyra: nej
Batterikapacitet: 52,5 kWh
Förbrukning (kwh / 100 km): 13.2
Toppfart: 150 km / h
Acceleration (0-100 km / h): 10,6 s
max. Moment: 255 Nm
Sittplatser: 5
Bagagerum: 479 / 1,367L
Vikt (kg) 1555
Släpvagnslast (kg) ännu inte tillhandahållen.
L / W / H (mm) 4544/1818/1536
Däck: 205/60 R16
Laddningsalternativ:
Standardanslutningar: AC-typ 2 1-fas 6,6 kW, DC CCS 50 kW
Anslutningar valfritt:
Faser: 1
Laddningstider i timmar vid 52,5 kWh (11 kW 3Ph):
Schuko 2,3kw: 23 h (23 h)
Vägglåda 3,7 kW: 14 h (14 h)
Vägglåda 4,6 kW: 11 timmar (14 timmar)
Vägglåda 7,2 kW: 8 h (14 h)
11 kW laddningsstation: 14 timmar (5 timmar)
22 kW laddstation: 8 timmar (5 timmar)
Snabbladdare möjligt: ​​Ja
Snabbladdning vid 50 kW (80%): 40 min
(Snabbladdning vid 100 kW) (80%): 25 min
Standardutrustning:
elektriskt taklucka
Integrerat bagagehylla i aluminiumlegering
LED dagsljus
LED bakljus
Automatisk värmepumpsluftkonditionering med konstant temperatur
Ventilation på bakre raden
PM2.5 luftdammfilter
Joniserande luftrenare
Skinnstol av hög kvalitet
elektrisk förarsäte med upp till 6 positioner
Manuellt ryggstöd för förarsätet
manuell passagerarsäte med upp till 4 positioner
elektrisk uppvärmning av framsätet
Fällbart säte bak 4/6 uppdelat
Öppna bagagerumslocket på avstånd
Bluetooth smart nyckel
Smart nyckellös post
Multifunktionsratt i läder 4-vägs ratt manuellt justerbart
Automatisk spegel mot bländning
Yttre speglar för elektrisk uppvärmning
Sidospeglar kan vikas elektriskt
Strålkastarna tänds automatiskt
Yttre spegel integrerad LED
Blinkers
Automatiska vindrutetorkare med regnsensorer (stöd för röststyrning)
HiFi-högtalarsystem
USB-port (med laddningsfunktion, två före och efter)
12V strömförsörjning framför
Bredden på främre / bakre raden för det centrala armstödet (med kopphållare)
Framspegel med ljus / läslampor fram och bak / glasögon / kartficka
Bagageutrymme belysning / förvaringsväska / skyddsgardin
Dubbel airbag på framsidan
Främre airbag
Luftgardin i ett stycke
Elektroniskt stabilitetssystem för ESP-kroppen
ABS-låsbromssystem
Elektroniskt bromskraftfördelningssystem EBD
CBC hörnsbromsstyrsystem
TCS-styrsystem
VDC-styrsystem för fordonsdynamik
HHC-styrsystem med rampstöd
BDW-rengöringssystem för bromsskivor
HBA bromskraftsassistanssystem
Direkt intelligent däcktryckövervakningssystem
Larmfunktionen när strålkastaren inte är avstängd
Mycket känslig radar efter varning
CCS kryssningskontrollsystem
LDW Lane Keeping Assist
AEB automatisk nödbromssystem
FCW varningssystem för frontkollision
SAS hastighetsassistanssystem
Strålkastare för hög- och lågstrålaromkopplare automatiskt
Ratt tillbaka för att komma ihåg
EPB elektroniskt bromssystem
Håll automatiskt parkeringssystem
Funktion för centrallåsdörrkontroll
av föraren
Snabblås automatisk låsning
Följ mig hem med min hemfunktion
Funktion för påminnelse om nödbromsbelysning
LED hög bromsbelysning
Barns lås bakdörr
Fast gränssnitt för ISOFIX barnstol
Smart anslutning
8-tums HD-pekskärm med hög upplösning
7-tums interaktivt semi-virtuellt instrument
Interaktiv interaktion med två skärmar (interaktiv visning av instrument och värd via navigering, fordonsstatus, musik osv.)
Höghastighetskommunikationslänk (4G-kommunikationsnätverk, Bluetooth 4.0, tvåvägs WiFi för biltelefon)
Bluetooth-system
Bluetooth-knapp för mobiltelefon
Anslutet underhållningskörningssystem
-IOS Carplay / Android Carlife
Bluetooth handsfree
Fordonsapp
Ytterligare alternativ våra kunder vill ha för e-Kombi:
Dragstång med 750 kg obruten, ytterligare dragbelastning kommer att kontrolleras.
V2X, det kan vara möjligt att fordonet kan ge upp till 3 kW för utomhus- eller till och med V2G via AC-anslutningen.
11-22 kW AC-laddare 3Ph, detta skulle ersätta den befintliga 6,6 kW AC-laddaren 1Ph.
Plug & Charge: aktivering av kolumnen via bilen, utan kort, utan app.
https://www.ludego.com/e-kombi/
Men som påtalats innan, i Kina är det tillverkaren som får subventioner från staten vilket gör att det redan är avdraget från priset. Lägg där till frakt, tull, moms mm så kommer priserna här i Europa vara betydligt högre.
Från ett forum i England.
200 miles+ WLTP range (approx 60kWh battery TBC)
£20-25k price (TBC)
578 Litres of boot space (1456 litres with seats folded!)
CCS charging (under MG badge)
Launching July 2020 - first deliveries due September 2020
2000 available for 2020 delivery (Q3/Q4)
Ja, alltid bra med dragstång ;)
MG5 kombi kommer nu också till Norge.
Blir mycket intressant! Billig och bra!
MG ZS EV(239.900Nok)har ju på kort tid blivit en stor succé i Norge.
Hamnade på femte plats alla kategorier i juli månad i försäljning.
Kan MG5 kombi slå det?
Drag på 750kg har den!
MG5 EV
Den får en batteripakke på 52,5 kWt, omtrent som småbilene Peugeot e-208 og e-2008, Opel Corsa med flere, men her får man kun 116 hk og 255 Nm, omtrent det de tidligere nevnte gir i normalt kjøreprogram. Det skal gi en elektrisk WLTP-rekkevidde på 34,4 mil, en toppfart på 150 km/t og akselerasjon fra stillestående til 50 km/t på 4,8 sekunder.
Den skal kunne lades opp til 80 prosent på 40 minutter under ideelle forhold og fra tom til full på 8,5 timer med ombordladeren på 6,2 kW. Forbruket er oppgitt til 17,5 kWt pr 100 kilometer.
Den kan bli et svært attraktivt valg for mange med en pris under 300.000 kroner, særlig dersom den får lovet bagasjerom på 578 liter og 1.456 med setene nedslått.
https://www.dinside.no/motor/ny-billig- ... g/72710180
Laban
Inlägg av Laban »
115 hk, 6.2 kW laddare är ingen höjdare direkt. Men med ett 578l bagageutrymme samt lågt pris så spelar det kanske ingen roll. Och 52 kWh ska ge 34 mil WLTP vilket är helt ok. SR+ har väl 40 mil som jämförelse. Jag vill se mer av denna typ av bilar.
Cybertruck AWD beställd
Model Y LR AWD beställd
MG ZS EV får ju ett 73kWh batteri nästa år, med ca 500km i räckvidd.
Gissar att MG5 också får ett 73kWh batteri.
Wahll
Inlägg av Wahll »
eller
"Ratt tillbaka för att komma ihåg"
MODEL ≡, DM LR Svart Aero FSD
Nissan Leaf -15
MG5 EV WARRANTY
Built to the highest standards in our state-of-the-art factories, we are so confident of the quality and reliability of MG5 EV that we give it a 7-year manufacturer’s warranty. Our warranty is fully transferable to future owners and lasts for up to 7 years or 80,000 miles, whichever comes first. So, from day one to the end of your car’s seventh year, you can be sure that MG is right beside you!
https://www.chorleygroup.co.uk/mg/new-cars/mg5-ev/
Imponerande med 7 år och
128.000km garanti.
Revoltra
Inlägg av Revoltra »
Finns tydligen inga planer på att släppa MG5 i europa. (förutom UK antar jag)
MG Motor will bring the MG5 full battery electric touring wagon (or ‘estate car’ as the Brits say) to the UK starting from the fourth quarter 2020. With a WLTP rated range of 214 miles, and an outstanding 7 year warranty, the price of £23,995 (after incentives) seems like a great value. Will it share the success of its pioneering sibling, the MG ZS EV, and become one of UK’s best selling full electric vehicles?
Just as a reminder, the MG5’s existing compact SUV sibling, MG ZS EV (from £25,495 after incentives) has been an instant hit in the UK. In the first half of 2020 it grabbed the country’s 3rd best selling full battery electric vehicle (BEV) spot:
MG have also achieved decent results with the ZS EV elsewhere in Europe. Year to date, it’s the #5 best selling BEV in the Netherlands, and the #10 best selling BEV in Norway.
https://cleantechnica.com/2020/09/11/mg ... der-24000/
MG har verkligen gjort succé med sina elbilar i Europa på kort tid.
I Frankrike kostar MG ZS EV 17.990 euro.
Nu visar det sig att MG5 EV kombi(Har möjlighet till drag)
Är ca 6% billigare än så.
Hoppas bara att MG snart kommer till Sverige så att elbilspriserna pressas rejält för alla elbilsköpare.
Nu pratas det om att även MG5 kombi kan få 73kWh batteriet och därmed ca 500km i räckvidd.
MG'S NEW EV ESTATE PRICE ANNOUNCED
MG's newest car, the MG5, is set to cost lest than 25k.
MG's parent company, SAIC has been developing their next car for the U.K. market, the MG5 EV estate. What is pretty much a re-branded Roewe Ei5, could become a massive hit here in the U.K., as the lack of something similar in its price range could mean that this new EV may fill a large gap in the market for an electric estate car at a decent price.
I've been following the MG5 EV ever since it was announced earlier this year and now I'm excited to say that a price has been revealed.
A very enticing price of £23,995 (with the government subsidy of £3000 included) had been announced for the car. Already, the MG5 is off to a great start. Remember the MG ZS EV was not too dis-similarly priced when it was launched, so in a sense the MG5 is offering similar style, but with better trim and equipment then the ZS EV for a similar price.
When the MG5 is released in Q4 later this year, the pricing will position it well enough, that it will become one of the most affordable electric estates in the U.K. which could move MG as a brand up to new heights and keep it growing even in the current crisis that the global motor industry is going through due to the pandemic.
Also announced, was the trim levels for the MG5. Similar to the MG ZS EV, the MG5 will have two trim levels, Excite and Exclusive, with Exclusive, presumably being the top model in the range.
Although full specifications have yet to be released, MG have announced some updated figures for the new 5 in comparison to the ones available back at the beginning of the year. As expected, the MG5 will have some differences in power from its Chinese sister, with a power output of 156bhp. This is a fairly large increase of 42bhp from the figures released before. Along with this, we can probably expect the 5 to be updated a fair bit from the Ei5 so that it sits well with the other competition in the U.K. market.
With the lack of official details, it is hard to say much about the details of the car, but the announcement from MG claimed a combined range of 214 miles (344 km) and a city range of 276 miles (444km). MG Motor UK has also previously hinted at a 73kWh battery and a possible range of 500km. SAIC has added that it would weigh the same as the 44.6 kWh battery that is in the MG ZS EV but we cannot confirm this until official figures are released.
Customers can now register their interest for the new MG5 and we can expect to see it released here in the U.K. in Q4 of this year.
https://drivetribe.com/p/mgs-new-ev-est ... AvO0BahXGw
Om MG ZS EV ligger i topp 3 i många länder i försäljning med 44,5 kWh batteri.
Hur bra kommer inte en MG ZS EV eller MG 5 kombi,
sälja med 73kWh batteri med ca 500km i räckvidd?
backe
Inlägg av backe »
Spännande.
Vet du något om när den kan tänkas komma till Sverige, MG5 alltså.
Spännande.
Det jag vet är att MGs svenska sida är uppe nu, men utan priser.
https://mgmotor.eu/sv-SE/
I England börjar MG5 kombi säljas Q4.
https://mg.co.uk/mg5-ev/
Vet inte om/när MG5 kombi kommer till Sverige.
SAIC har ju både Maxus och MG.
Gissar de svenska Maxus handlarna även börjar sälja MG i Sverige.
nek0
Inlägg av nek0 »
Spännande.
MG har ännu inte släppt alla tekniska detaljer om kombimodellen ännu, men räckvidden ska ligga på omkring 34 mil enligt WLTP-körcykeln. Effekten kan hamna på drygt 160 hästkrafter och modellen blir framhjulsdriven.
När det gäller snabbladdning ligger dock inte MG 5 längst fram i utvecklingen. Att ladda till 80 procent tar 50 minuter.
Med en längd på 4,54 meter ger sig MG 5 in i ungefär samma storleksklass som Volkswagen Golf Sportscombi. Sju års nybilsgaranti blir standard.
De första leveranserna ska köras igång under fjärde kvartalet i flera länder, bland annat England, där prislappen börjar på motsvarande 270 000 kronor inklusive elbilspremien.
https://www.vibilagare.se/nyheter/premi ... g-prislapp
Björn Nyland laddar i 72kW.
nek0
Inlägg av nek0 »
10-80% 72kW? Då går det undan :)
backe
Inlägg av backe »
Ingen bil för mig personligen tror jag, men det är riktigt bra att det kommer billigare alternativ.
För många spelar mycket av det som jag bryr mig om inte någon roll alls, man kanske bara vill ta sigt till affären och stugan fram och tillbaka och då kan det här bli ett kanon alternativ.
Bra att det kommer billigare elbilar.
Nu när VW ID3 har lanserats, då sänkte plötsligt Kia privatleasing priset från 5.195kr till 3.995kr per månad.
Kia e-Niro 64kWh.
https://www.blocket.se/annons/skane/kia ... _/92037057
