Nya Nissan Leaf
- TiborBlomhall
Re: Nya Nissan Leaf
Är beredd
Re: Nya Nissan Leaf
Vet att de inte börjat än men smart att bilen stannar helt även i backar av att man bara släpper gasen, då blir det verkligen en pedals körning. Gäller detta även nuvarande Leaf?
Re: Nya Nissan Leaf
Nissan claims the new Leaf’s 40 kWh battery will provide 150 miles of range under EPA testing and 400km (248.5 miles) under the Japanese JC08 cycle
Re: Nya Nissan Leaf
It is powered by a 40kW battery which has a max output of 150PS and 320Nm of torque allowing a top speed of 90mph
The car’s luggage space has also bee increased to a decent 435-litres.
That is 41bhp more than today’s 30kW range-topper and enables it to accelerate from 0-62mph in about eight seconds
Price £27,000 (est) Engine 40kWh electric motor Power 148bhp Torque 236lb ft Gearbox Single-ratio reducer Kerb weight 1535kg 0-62mph 8.0sec (est) Top speed 89mph Range 235 miles (NEDC
For those seeking an even longer-range EV, a second Leaf model, likely dubbed e+, is coming soon with a 60-kWh battery, giving it a range of "at least 225 miles." That figure will pit it squarely against the class-leading Chevrolet Bolt EV (238 miles) as well as the base Tesla Model 3 (220 miles
The battery can be charged in 16 hours using 3 kW charger, or 8 hours using a high-output 6 kW hour charger. A quick charge option will allow it to gain back 80 percent of its charge in just 40 minutes, too. Higher range, higher power performance version will be available at additional cost in 2018
Re: Nya Nissan Leaf
Tennessee-built Leaf will start at a price that's actually cheaper than its forbear: $29,900 plus $885 delivery. That's $690 less than a 2017 model, yet the new car features more range, performance, and equipment. If the Leaf can't win on battery capacity, Nissan intends to put the hurt on rivals with its value.
Next year’s 60-kW Leaf e+ will be the first CHAdeMO-capable car to offer 100-kW charging in the United States (versus a 50-kW max for the standard car).
Charging time from alert to 80% (Quick Charging)
40 minutes
The company put a great deal of effort into reducing cabin noise in the 2018 Leaf, and it shows.
They range from a stiffer structure and extensive computer modeling of noise and vibrations to acoustic glass in the windshield and insulation specially designed to absorb whine from the motor and electronics
The result is that the new Leaf is noticeably quieter than the 2017 model
Nissan has included a few edge features, like vehicle-to-grid capacity, which enables owners to use their car’s battery pack to power their home
40 minutes
- TiborBlomhall
- TiborBlomhall
Re: Nya Nissan Leaf
En tanke som dyker upp i mitt huvud är tajming.
Låt säga att Leaf 2 40kwh kan börja levereras i mars 2018, men då känns det frestande att vänta till 1juli för att få 60.000kr i miljöbilsstöd.
Men väntar man till 1 juli, då kanske Leaf 2 60kWh kommer i oktober, och väntar man till oktober, då kan man ju lika gärna vänta lite till på en Tesla 3!
Re: Nya Nissan Leaf
Bra jobbat nattugglan Tibor!
Några positiva nyheter (och några besvikelser) blev det iaf
Re: Nya Nissan Leaf
Alltså inte en reell konkurrent till 3:an. Den kommande 60 kW-versionen uppfyller bara ett av mina 3 grundkrav.
Re: Nya Nissan Leaf
Varför förstår man inte skillnaden på kW (effekt) och kWh (energimängd). Ett batteri på 40 kW betyder det att man kan Max dra 100A och 400V?
Re: Nya Nissan Leaf
Håller med konstigt att detta inte kan sätta sig.Remuz skrev:Varför förstår man inte skillnaden på kW (effekt) och kWh (energimängd). Ett batteri på 40 kW betyder det att man kan Max dra 100A och 400V?
Re: Nya Nissan Leaf
Jag tycker att den är helt klart en konkurrent till Model 3. Förutom att den uppenbarligen inte får trefasladdning är den inte så tokig. Visst, ingen dragkrok. Men att Model 3 får dragkrok tror jag först när jag ser det med egna ögon. Jag litar inte på Elons twitter-löften längre.
Re: Nya Nissan Leaf
Väcker inget direkt ha begär när jag ser den, invändigt eller utvändigt. 0-100 på 8s är helt ok, men inte mer. 40 kWh/50 kW är för lite för att vara långfärdsbil för våra behov. Ingenting om dragkrok och det är väl troligt att den inte får det.
Men ur ett globalt elbilsperspektiv så är jag ändå rätt nöjd. De gjorde inte misstaget att göra ett större batteri och höja priset utan sänkte det, om än då marginellt.
Cybertruck AWD beställd
Model Y LR AWD beställd
Re: Nya Nissan Leaf
Rätt ok utvändigt. Men vad är det för en smutsig vit låda med avskavd färg på hörnen som sitter under huven?
Model S P85DL+
Re: Nya Nissan Leaf
Dom har iaf lyckats att fortsätta fylla hela utrymmet under huven...
Re: Nya Nissan Leaf
Jag ska iaf begära in en offert. För mig är den helt klart intressant.
- Gustafsson
Re: Nya Nissan Leaf
Kommer nog också att provköra. För mig är totalekonomin en stor faktor, vad blir månadskostnaden, förmånsvärde mm. Dock är endast 60kWh versionen av intresse. Intressant elbilsår 2018!
Re: Nya Nissan Leaf
Bra strategi av Nissan, driftsäkerbil till "lågt" pris.
Lite lustigt att de redan nu avslöjar att 60kWh versionen kommer sent 2018, alltså om ett år och leverans till Sverige 2019. Kanske för att de tidigare lovat att Leaf 2 skulle ha 60kWh.
Undrar om de löst kylningen av batteriet? Får hoppas att några riktiga elbiljournalister får tag i bilen så att de kan testa betydelsefulla saker.
